Latest: tebas93089
Overall: 17179
Online Now [128]:
Visitors: 127
Today: 1974
Total: 137967618
Forums › The Car › 206 Problems › Help from someone with a multimeter/light tester
Rob2859
PostPosted: Thu Sep 08, 2011 9:07 am Up
Nothing major just a 10 min job, no unplugging or anything required. Please can someone check some wires for power when the ignition is off and the BSI has shut down?
Just touch each wire on each plug in the engine bay fuse box and tell me which ones have power. On mine only the purple wire on plug EP1 NOIR has power. Also by touching the purple wire on plug PP1 VERT it made the wipers come on.
Also there is one plug on the BSI (interrior fuse box) I would like testing. Its a grey plug with a red clip on it, and it has two thick wires on it; one is black the other red. Please test for power on both wires. Again making sure the BSI has shut down.
This is the last attempt at trying to trace a problem before going to another electrician; who hopefully can figure out what it is.
ukskater01
PostPosted: Thu Sep 08, 2011 2:37 pm Up
If I had a multiplexed 206 I would mate,
what's the problem?
Rob2859
PostPosted: Thu Sep 08, 2011 7:12 pm Up
Many many things. Power going to where it shouldn't, things working without fuses all well as others.
