Latest: lio94
Overall: 17181
Online Now [184]:
Visitors: 183
Today: 45330
Total: 140989871
Forums › The Car › 206 Problems › Easiest Way
Easiest Way
LilLew
PostPosted: Thu Sep 08, 2011 11:48 am Up
Hi all
what is the easiest way to remove the drive shaft to change outer cv boot this is the way i am guessing just by looking
undone track rod end bolt
take brake caliper off tie out of the way
undone the suspeion bolt
take split pin out undone hub nut
knock the hub down to get the suspenion arm out of it then pull drive shaft out of gearbox plugging the hole with some paper
finally remove out of hub
2003 Pug 206 2.0 GTI 180
Rob2859
PostPosted: Thu Sep 08, 2011 12:08 pm Up
You don't need to take the hub from the strut and you don't need to remove the shaft from the gearbox. You can pull the hub far enough out to get the shaft out. Then take off the inner boot and remove from the rest of the shaft. You don't have to make a mess then and its easier than getting the whole shaft out.
Someone best confirm this as its a 180 but you should be able to do it that way.
PostPosted: Thu Sep 08, 2011 12:27 pm Up
I thought there was kits that meant you didn't have to remove anything. Just cut off the old one & slip the new one on & seal it.
kieron
PostPosted: Thu Sep 08, 2011 12:52 pm Up
www.ebay.co.uk/itm/New...3a69a1e7a8
like this but they may not last long
Account suspended
00budham00
PostPosted: Thu Sep 08, 2011 1:01 pm Up
That looks s**t ! eBay crap to cut corners
LilLew
PostPosted: Thu Sep 08, 2011 1:29 pm Up
yer i agree with the ebay crap its a glue one i dont think it would last 5mins
PostPosted: Thu Sep 08, 2011 1:57 pm Up
that's all you need before selling a car/ pass mot Cool
PostPosted: Thu Sep 08, 2011 2:00 pm Up
i couldn't believe this...
www.toyota.com.au/owne...-boot-kits
PostPosted: Thu Sep 08, 2011 2:08 pm Up
remove wheel
undo lower arm bolt and remove ball joint from hub
undo centre nut and tap out shaft with copper mallet
replace boot
the shaft should come out without having to remove anything else Smile
