Online Now [56]:
Visitors: 56
Today: 27018
Total: 105035410
Forums › The Car › 206 Problems › Coolant bleed screws and drain screw location on 1.4HDI?
pottry
PostPosted: Thu Sep 08, 2011 2:54 pm Up
So this is it. I know the location of the bleeding screw at the pipes that go to the heating radiator.
However I can't find the second one (is there second one at all)?
I spent 1 hour trying to find it (presumably somewhere near the termostat) and I couldn't.
Also do the 1.4HDI has a draining plug for the coolant on the engine?
Pics would be invaluable!
Thanks!
Peugeot 206sw, 1.4HDI
skinny
PostPosted: Thu Sep 08, 2011 3:36 pm Up
just remove the bottom hose
would be much easier to drain out
Pug 206 1.4 Hdi
Pug 206 Gti 138
Bassline_Toad
PostPosted: Thu Sep 08, 2011 3:41 pm Up
What He Said
Not to mention, isn't the thermostat near the top? Why would th drain plug be up there?
pottry
PostPosted: Thu Sep 08, 2011 4:14 pm Up
Read carefully, don't embarrass yourself.
Still, if somebody KNOWS something on the matter please share.
Thanks.
Bassline_Toad
PostPosted: Thu Sep 08, 2011 4:26 pm Up
Don't be a bellend mate, we get enough around here. You're just another statistic. I'm trying to be helpful.
PostPosted: Fri Sep 09, 2011 1:44 am Up
the main plug to drain the engine coolant should be near to the flywheel (not 100%sure)
the bleed point is on the thermostate housing, if you can't find it you can remove the coolant sensor to blled it.
the last one is on the top of the radiator (big plug)
pottry
PostPosted: Fri Sep 09, 2011 9:33 am Up
OK I guess I will be searching tomorrow...
But still if somebody has a manual for the 1.4HDI engine similar to this one:
http://www.peugeot206cc.co.uk/repair-206/206/info/gb/b1gi0nk3.htm
,or has the same car and knows for sure where the points are, let me know.
