Latest: Daz682237
Overall: 17136
Online Now [97]:
Visitors: 96
Today: 32280
Total: 110844480
Forums › The Car › 206 Problems › 206 1.1 look speedo swap
woody
PostPosted: Sun Sep 11, 2011 2:36 am Up
Hi guys wonder if someone can help. I have a 2003 206 1.1 look, the speedo and rev counter has packed up. The speedo type is a single plug and I have found a replacement from a scrap yard with a lower mileage then the current one. Now from what I can tell from conversations on the forum’s is that the new clocks should default to the mileage currently shown in the car. Am I correct? Also could someone explain what you mean by plexed and multiplexed I understand the difference just don't know what is meant by plexed / multiplexed and how you can tell which you have. Any help would be much appreciated. Thanks Chris
iainlovatt
PostPosted: Sun Sep 11, 2011 4:05 am Up
Different type of wiring buddy!
swap them over, i think from what i remember they should sink to your current mileage.. Very Happy
(My Garage)
woody
PostPosted: Sun Sep 11, 2011 4:54 am Up
cheers mate thanks for your help
Chris Wood
Antknee
PostPosted: Sun Sep 11, 2011 5:21 am Up
You can dell the difference by looking at your steering wheel headunit control stick, if its a little thin one its pre, if its a bigger oval shaped one its a mux
PostPosted: Sun Sep 11, 2011 8:24 am Up
Just fit them & the mileage will be correct.
BUT - Ive never heard of a multiplexed instument cluster failing before.
woody
PostPosted: Sun Sep 11, 2011 10:30 am Up
Thanks for your help guys ive just change the speedo over and its default to orignal mileage. so spot on.
cheers guys
Chris
