Latest: TigerHunters
Overall: 17144
Online Now [84]:
Visitors: 83
Today: 12396
Total: 115885638
Forums › The Car › 206 Problems › Knocking from the rear
Antknee
PostPosted: Sun Sep 11, 2011 12:50 pm Up
Already replaced the exhaust mounts and removed the spare wheel, cage and the hook and bolt that holds it up
Hoping its not a sign i need a new rear beam Sad
Any suggestions of what i can look for?
PostPosted: Sun Sep 11, 2011 12:52 pm Up
jack it up and check for play in the wheel (wheel bearings) or trailing arm (trailing arm bearings) thats what i would do next anyway.
PostPosted: Sun Sep 11, 2011 12:53 pm Up
Boot rattle?
Antknee
PostPosted: Sun Sep 11, 2011 1:08 pm Up
Thanks, How would i check for play in the trailing arms?
I'll tape up the boot in the morning before work and see how it goes, there's this one bad road on the way where it sounds like the back end is gonna fall off lol
PostPosted: Sun Sep 11, 2011 1:59 pm Up
I gave up tracing every knock and rattle on my car, unless they are bad, because you'd be forever fixing little noises!
tvauders
PostPosted: Sun Sep 11, 2011 2:43 pm Up
Check to see if your shock absorbers are loose, or that the exhaust is knocking against the underside of the car.
Failing that, you're probably going to need a new rear axle. Has you lowered the rear end excessively in the past? or has it ever been?
The bearings in the axle could be shot, and from memory you can't just replace them, the whole thing would need replacing.
You could try taking off your rear wheels and making sure the ARB hasnt worked loose. Basically it could be a lot of things lol.
Used to own a 206 XSi
Antknee
PostPosted: Sun Sep 11, 2011 4:04 pm Up
i know but this one is a recent one and its getting on my tits, its louder than the music sometimes Laughing
cheers, i'll take the wheels off tomorrow after work and see what's going on
if it helps i can bounce the rear when the car isnt moving and its fine, its when im moving over a bumpy road it happens mainly
