Latest: Kifi69
Overall: 17183
Online Now [372]:
Visitors: 371
Today: 102779
Total: 143762900
Forums › The Car › 206 Problems › almost there one more problem
LilLew
PostPosted: Sun Sep 11, 2011 3:53 pm Up
Hi all
i have been finishing the work on my 180 to get her back on teh road after failing the M.O.T
axle bearings (Done only one side needed replacing)
hand brake (Done set of new cables)
cv boot (New one fitted)
exhaust mount (Bent the mount arm and out a new rubber on it)
loose drop links (re tapped the thread and brute force)
after doing all of this i have came to the great job of bleeding the brakes
3/4 bleed nipples snapped so i brought a easy out kit and that snapped as well there is no way they were being undone so i drilled them out and replaced them with some mate bolts
i am now having problem bleeding my brakes i cant seem to get any pressure in the pedal at all and about half way down when pressing the pedal there is a clonk noise
when i undo the bleed nipple and press the pdeal the fuild just dripples out
sorry for it being long winded and grammar (dyslexic)
2003 Pug 206 2.0 GTI 180
PostPosted: Mon Sep 12, 2011 12:41 am Up
Just sounds like it's still got air in the system. Check the new bleed nipples are in ok & try again, preferably with an assistant.
Deckchair5
PostPosted: Mon Sep 12, 2011 1:15 am Up
You can't build up fluid pressure in a system full of air so I would use a one man bleed kit, they're quite cheap and, similar to how it's done in a garage, this pushes fluid through the whole system without relying on the master cylinder for pressure.
Read the instructions on how to use it though, if you are going to use your tyre to supply the air pressure then reduce the pressure from normal first, around 10psi max is all you need
click here<<
PostPosted: Mon Sep 12, 2011 2:01 am Up
GTI 180 brake bleeding should really be done with Peugeot Planet else you can damage the ESP system.
LilLew
PostPosted: Mon Sep 12, 2011 2:48 am Up
i have been told by a bmw mech that you should connect it up to the computer and tell it to run the abs pump while you bleed the brakes else the abs wont work at all
Deckchair5
PostPosted: Mon Sep 12, 2011 9:14 am Up
Yes, if you have air trapped in the ABS unit then the ABS unit valves may need to be cycled to clear out any air pockets in there. However a one man bleed kit puts no strain on anything inside the ABS unit and is the first thing to do in order to refill the system
Linkpad
PostPosted: Mon Sep 12, 2011 1:28 pm Up
Just out of curiousity how did u replace your axel bearings ?
Boo
LilLew
PostPosted: Mon Sep 12, 2011 3:07 pm Up
easy enough to be honest
1. jack rear car up and put on axle stands (point 2)
2. remove wheels, disconnect hand brake cables, unplug ABS sensors
3. undo brake pipes from calipers (get a pot ready to collect old fuild)
4. crack off all four axle bolts (DO NOT REMOVE)
5. put wheels back on lower car back on two wheels
6. slide under the car and remove axle holding bolts (BEWARE axle will fall forwards)
7.jack the car back up and roll axle out from under the car.
8. get a big mate to pick it up and put it on a work mate.
depending on which side you need to remove let me know
LilLew
PostPosted: Mon Sep 12, 2011 3:16 pm Up
ill take some pics of each side of my axle and label all the bolts you need to remove
LilLew
PostPosted: Mon Sep 12, 2011 3:21 pm Up
here is a guy on your tube which show you the way he does it
PART 1
www.youtube.com/watch?v=48eP5KZdSFs
PART2
www.youtube.com/watch?...ure=relmfu
PART3
Linkpad
PostPosted: Mon Sep 12, 2011 11:58 pm Up
OK thanks ! Great info ill take a look when i get time
Boo
