Latest: lio94
Overall: 17181
Online Now [246]:
Visitors: 245
Today: 51269
Total: 141690938
Forums › The Car › 206 Problems › manifold bolts help
manifold bolts help
20619d
PostPosted: Mon Sep 12, 2011 11:36 am Up
one of my manifolds bolts have snaped(where joins to down pipe) the spring bits have gone. i have manage to bolt tight but down pipe still rocks side to side abit. it also blown to.
can i buy new bolts to put in or can i get away with filling it with gum gum paste?
please can someone help
PostPosted: Mon Sep 12, 2011 11:53 am Up
Just go spend £12 at any Peugeot / Citroen dealer for the downpipe fitting kit.
20619d
PostPosted: Mon Sep 12, 2011 11:57 am Up
how easy is it to get bolts of from manifold?
parkesie
PostPosted: Mon Sep 12, 2011 1:37 pm Up
Messy ass job would need to get a drill in to hole it and get a easy out in to it. probably end up snapping the other studs aswell.
Signature p**s
PostPosted: Mon Sep 12, 2011 1:39 pm Up
Push it up through the hole.
The Peugeot / Citroen fitting kit has all the new bolts, washers, nuts, springs you need.
20619d
PostPosted: Mon Sep 12, 2011 1:45 pm Up
it the bit in the manifold that stuck. it snapped by the spring hence why spring fall off. will it just undo or is it welded in?
PostPosted: Mon Sep 12, 2011 1:46 pm Up
Its just a bolt, it will be rusted in.
20619d
PostPosted: Mon Sep 12, 2011 1:48 pm Up
so cut down and drill out?
parkesie
PostPosted: Mon Sep 12, 2011 2:14 pm Up
drill and stud extractor it out Pain in the ass to get at with a drill.
Signature p**s
PostPosted: Mon Sep 12, 2011 2:16 pm Up
Knock it out Rolling Eyes they fit in from the top of the manifold Wink
Go buy the fixing kit first to see what your dealing with.
20619d
PostPosted: Mon Sep 12, 2011 2:18 pm Up
f*****g car may fill it with paste and use some time of clamp on it
PostPosted: Mon Sep 12, 2011 2:20 pm Up
Just take it to a fast fit place then, they will have fixed thousands of these over the years, Peugeot / Citroen has been using this set up for 25+ years that I know of.
20619d
PostPosted: Mon Sep 12, 2011 2:21 pm Up
is there no way i can just knock out and put bolt and nut on it for now untill get paid?
20619d
PostPosted: Mon Sep 12, 2011 2:22 pm Up
just tryin for quick fix untill get paid
parkesie
PostPosted: Mon Sep 12, 2011 2:29 pm Up
knock out if its the splined fit stud. Relatively easy compared to a threaded stud. once its out just put a bolt through til you can get the correct fittings.
Signature p**s
