Latest: jackrox1992
Overall: 17186
Online Now [624]:
Visitors: 624
Today: 139594
Total: 147854392
Forums › The Car › 206 Talk › What is this for??
What is this for??
Forum Index › 206 Talk
tubbe2
PostPosted: Fri Sep 16, 2011 3:01 pm Up
As the title says, what on earth is this connection used for? (pictured, blue wire)
As you can see on the picture, the wire has been cut of/broken, it was connected to the plug (marked with red) which you can see in the right corner (it's located just over the oil filter). The copper was green from oxidation, so it seems like it's been like this for quite a while Confused Anyway, I fixed it up and put it back on - so now I'm wondering what it's for? Rolling Eyes
Also, if you know what the other connection plug (the one hanging loose) is used for, please tell Laughing
2002 Peugeot 206 GTi 2.0 16v 137Bhp
PostPosted: Fri Sep 16, 2011 3:12 pm Up
any numbers on the wires?
Harty
PostPosted: Fri Sep 16, 2011 8:45 pm Up
kinda looks like the reverse light switch but i may be way wrong, can you get better pictures up? failing that i'm sure someone else will know
Harty
PostPosted: Sat Sep 17, 2011 12:40 am Up
This is where it's supposed to sit...it sits on top of the oil filter housing but it's not the oil pressure sensor. It just seems to be a connector to bridge the loom.
macj
PostPosted: Sat Sep 17, 2011 2:21 am Up
Is there a wire in the black trunking in the top right of picture??
tubbe2
PostPosted: Sat Sep 17, 2011 3:59 am Up
Black trunking? you mean the protective thingy? Razz That's the connector I'm talking about, the other part of the cut off blue wire is inside that, I revised the picture for it to make a bit more sense Rolling Eyes - will see if I can get a better pic today.
PostPosted: Sat Sep 17, 2011 4:03 am Up
Is it for the air con pump? I'll have a look at mine shortly.
macj
PostPosted: Sat Sep 17, 2011 4:17 am Up
looks like the oil pressure switch to me..... Check yours Ed. The picture is taken from below and makes it a little confusing. I think its the oil filter just above it.
tubbe2
PostPosted: Sat Sep 17, 2011 4:30 am Up
The the oil filter is in the top right corner, you can just see the rusty ring and the round shape of it Razz
PostPosted: Sat Sep 17, 2011 4:32 am Up
What He Said
The broken wire on the loom, with the engine running touch it to earth & see if the oil pressure warning light flashes up on the instrument cluster Wink
PostPosted: Sat Sep 17, 2011 10:55 am Up
I was looking at the connector in the centre of thepicture which is definately for the air con pump. Didn't see the little red circles.
PostPosted: Sat Sep 17, 2011 11:35 am Up
I dont remember seeing the little red circles earlier either Confused
tubbe2
PostPosted: Sat Sep 17, 2011 11:38 am Up
I edited it after you mistaking, that it was that one Wink So you're not seeing ghosts Laughing
But I did also ask about that connector, I guessed it was air-con anyhow Razz
macj
PostPosted: Sat Sep 17, 2011 11:42 am Up
did you try earthing it??
PostPosted: Sat Sep 17, 2011 12:30 pm Up
Here's mine...
