Online Now [236]:
Visitors: 235
Today: 75795
Total: 142586214
Forums › The Car › 206 Problems › bloody brakes
bloody brakes
LilLew
PostPosted: Sat Sep 17, 2011 9:07 am Up
Hi all
i am still having problems bleeding my brake 3 out of 4 bleed nipples snapped so i have drilled them out and fitted some bolts
attached the auto bleed kit and went around and undone each bolt and the fuild comes out then do it back up a couple of times on each wheel and then unattach the auto bleed kit
press the pedal and there is little pressure so pump it and you get some good pressure so start the car and then you loose ALL pressure
PLESAE HELP
2003 Pug 206 2.0 GTI 180
panzer360gti
PostPosted: Sat Sep 17, 2011 9:11 am Up
swallow your pride and pay a mechanic, save your time
Peugeot 206 GTI 137 2.0
LilLew
PostPosted: Sat Sep 17, 2011 9:12 am Up
i have one problem the car has no mot or tax and i have no brakes so i cant get the car any where
PostPosted: Sat Sep 17, 2011 9:13 am Up
LilLew wrote:
Hi all
PLESAE HELP
You need bleed nipples not bolts.
GTI 180 needs bleeding with Peugeot Planet.
Your just wasting your time until the job is done CORRECTLY!
PostPosted: Sat Sep 17, 2011 9:25 am Up
How can you use an auto bleed kit using bolts in place of bleed nipples?
Go and buy some new nipples from either a dealer or motor factor.
macj
PostPosted: Sat Sep 17, 2011 9:26 am Up
What He Said
LilLew
PostPosted: Sat Sep 17, 2011 9:32 am Up
bolloxs looks like a set of new cailpers for me then
PostPosted: Sat Sep 17, 2011 9:40 am Up
why not use buy some bleed nipple....they are only a few quid each
LilLew
PostPosted: Sat Sep 17, 2011 10:05 am Up
because the orignial had to be drilled out because it snapped the easy out tools and the whole is slightly bigger then a bleed nipple
PostPosted: Sat Sep 17, 2011 10:19 am Up
measure the hole size and then get correct size; there is a whole range of bleed nipple avalible
PugJH
PostPosted: Sat Sep 17, 2011 10:39 am Up
ah i didnt read this, ignore my link to ebay item, measure the hole, also do you know what pitch the bolt was you put in? if not the hole might just have to get bigger
WIP: Black 1.6 16v XSi
Beauté Noire
parkesie
PostPosted: Sun Sep 18, 2011 2:31 pm Up
New calliper time.
woops
Signature p**s
Schumi
PostPosted: Tue Sep 20, 2011 2:30 pm Up
Can you explain ? Smile
2005 206 RC RED
broadblaster
PostPosted: Tue Sep 20, 2011 2:44 pm Up
if you have got air in the abs pump you will need peugeot planet to activate the abs pump to bleed the air out of it.
on a back road playing
Schumi
PostPosted: Tue Sep 20, 2011 3:18 pm Up
Hmm. I didnt know that. I know Peugeot Planet must be used when tracking on cars with equipped ESP for steering angle sensor.
2005 206 RC RED
