Latest: Worthy967
Overall: 17143
Online Now [554]:
Visitors: 552
Members: 1
Today: 29273
Total: 114454649
Forums › The Car › 206 Talk › Pug part # request for gearbox please
PostPosted: Sat Sep 17, 2011 10:11 am Up
Gearbox (MA) has been dripping oil for ages. I would be surprised if there
is any left in there. Embarassed
I would like to replace all the seals (drive shaft etc) but servicebox is
a bit ambigious regarding this.
Could someone show me on the relevant page which parts and codes
I have to order from my Pug dealer?
Mech will carry out the work but any other advise/thoughts generaly regarding this?
Thanks.
PostPosted: Sat Sep 17, 2011 10:17 am Up
i think there is only 2 oil seal on the box anyway...
both on the differential housing
3121 44 and 3121 46
PostPosted: Sat Sep 17, 2011 10:22 am Up
#3 and #4 below, any other seals that need replacing?
PostPosted: Sat Sep 17, 2011 10:57 am Up
as far as i know that is.
you sure the oil leak is from the driveshaft?
PostPosted: Sat Sep 17, 2011 11:02 am Up
Nope.
But it was definately gear oil. A very slow and small leak over time.
'Will take a better look as soon as I can.
PostPosted: Sat Sep 17, 2011 11:11 am Up
Nope.
because there is also gasket between the gearbox casting too.
PostPosted: Sat Sep 17, 2011 11:23 am Up
Seabook wrote:
Nope.
Exactly. I have a feeling it might be from there.
PostPosted: Sat Sep 17, 2011 1:56 pm Up
looks like a box off job then Laughing
PostPosted: Sat Sep 17, 2011 2:41 pm Up
Wait. I thought you mean #4 on here.
That wouldn't need box off unless I'm missing something?
PostPosted: Sat Sep 17, 2011 2:48 pm Up
4 don't need box off but i mean the surface/gap between those 2 big gearbox casting (non-number in the pic)
normally there is sealant in between
PostPosted: Sat Sep 17, 2011 3:19 pm Up
Are you sure about that because the clutch plate etc is above there.
I wouldn't think gear oil would be found in there.
There seems to be no gasket there on the drawings.
Maybe someone can confirm.
PostPosted: Sat Sep 17, 2011 4:49 pm Up
not that face....
this face...
PostPosted: Sat Sep 17, 2011 5:14 pm Up
Ah
PostPosted: Sat Sep 17, 2011 6:07 pm Up
better check where is the leakage from first, could save a lot of work.
PostPosted: Sat Sep 17, 2011 6:25 pm Up
Yep.
Will do. I just want to make a proper job of it because this has been going on for ages. Small, very slow leak but serious at this stage.
Cheers for the help and I'll keep the thread posted.
