Latest: Kifi69
Overall: 17183
Online Now [355]:
Visitors: 354
Today: 37048
Total: 144054960
Forums › The Car › 206 Problems › Bit stuck with a problem - 1.1 206 1998
PostPosted: Wed Sep 21, 2011 3:06 am Up
So a few months ago I was doing some work on a 1.1 206 for a friend.
The problems were:
1. Starting it and it would lose revs and die.
2. Start it and it would rev up to 4k rpm on its own.
So I changed the ICV and reset the ECU.
That sorted it for the time being, however it was SORN and it's only been MOT'd this week. Now last night it did the same thing, revving up to around 3-4k rpm.
Any ideas?
Thanks Smile
Ash
PostPosted: Wed Sep 21, 2011 4:12 am Up
Check the battery/alternator/wiring condition.
DanPug206
PostPosted: Wed Sep 21, 2011 5:01 am Up
Map sensor? When I've heard of this problem before, changing this normally fixes it. That's what I have read anyway
Saphire Blue 206 (Gti Replica) SOLD
08 Seat Ibiza Sport
PostPosted: Wed Sep 21, 2011 5:11 am Up
1) What is SORN?
2) Butterfly sticking in the throttle body or throttle position sensor or what Dan said?
PostPosted: Wed Sep 21, 2011 5:15 am Up
V9977 wrote:
1) What is SORN?
A SORN is a Statutaroy (sp?) Off Road Notice.
If you dont pay the tax for it to be on a road you have to declare it as a sorn to the DVLA otherwise you get a few nasty letters.
PostPosted: Wed Sep 21, 2011 6:00 am Up
If it does it again I'll get it changed.
Thanks for the replies Smile
oldskoolz
PostPosted: Wed Sep 21, 2011 8:14 am Up
as above, map sensor will solve it should the problem re-occur. changed the ICV on mine for the exact same problem and solved it for about a week. then changed MAP sensor and been running beautifully for nearly 2 years since.
Black 206 Gti. Soon to be 2.2
