Latest: lio94
Overall: 17181
Online Now [153]:
Visitors: 152
Today: 11969
Total: 141879137
Forums › The Car › 206 Problems › Heater control panel lighting
GP-F
PostPosted: Wed Sep 21, 2011 3:43 pm Up
the wife 2002 cc had a bulb out on the lighting behind the panel. So I took the console apart, removed the panel & changed the bulb that wasn't working.
Plugged it all back together & now NON of the lights work!??
Can anyone shed a light (forgive the pun) or point me at what could be wrong?
Its only a multipug to connect it up?
Is there a fuse? (interior light & dash ones work fine)
Confused
206CC
PostPosted: Wed Sep 21, 2011 3:49 pm Up
Did you fit LED's? Don't forget they are polarised
Check the fuses. When removing fuses, ensure the battery is disconnected correctly
GP-F
PostPosted: Fri Sep 23, 2011 7:43 am Up
nope standard ones. will check fuses but would of thought they are linked to dash lights & interior?
206CC
PostPosted: Fri Sep 23, 2011 7:52 am Up
They are all linked
Have you made sure you haven't unplugged the wiring?
GP-F
PostPosted: Fri Sep 23, 2011 9:25 am Up
The rest are fine & the multiplug which powers them runs the ac switch & rear screen, both of which work fine & light up. Going to try again & fit ALL new bulbs.
206CC
keikei
PostPosted: Mon May 28, 2012 3:59 pm Up
Hi,
How to remove heater control panel to change the bulbs?
Peugeot 206 - 1999., 1.4 GLX
Thanks.
Raquelle
PostPosted: Mon May 28, 2012 4:05 pm Up
Have to take the whole facia off, as it is actually behind the plastic coating, unlike a radio. It's simple as anything to do, however the bulbs are a pain to get out Smile
keikei
PostPosted: Mon May 28, 2012 4:23 pm Up
Do you know by any chance what kind of bulbs are there?
Link to ebay or something would do.
Thanks.
