Posted: Wed Sep 21, 2011 1:08 pm |
My driveshaft was slipping on Monday and yesterday it went. I recovered my car and had a look today. I already bought another shaft expecting it to be that. However its slipping inside the gearbox; Can we just confirm that it is f****d?
Also I was told the gear ratio's in 1.4's are shorter for some reason, can someone confirm this too?
Posted: Wed Sep 21, 2011 1:10 pm |
Sound like the diff has shat itself
is the differential working?
if you want to know the gear ratio check on servicebox
Posted: Wed Sep 21, 2011 2:45 pm |
The diff seemed to be working. I am looking on servicebox but struggling to find it =/
Posted: Wed Sep 21, 2011 3:41 pm |
This a common problem with the MA box as the crown wheel is simply an interference fit. When the cars have done a fair milage or been rallied about the crown wheen breaks off its normal location.
Two options
1. Bin the box and get another
2. Get a machine shop to open the box and pin the crown wheel in place (i have had this done and it work 100% now)
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Posted: Wed Sep 21, 2011 3:43 pm |
imjeeves wrote: |
Two options
2. Get a machine shop to open the box and pin the crown wheel in place (i have had this done and it work 100% now) |
so do you mean the crown wheel fall off from the differential?
can't believe that could happen hard to believe it can break through 8 bolts
Posted: Wed Sep 21, 2011 3:47 pm |
Thanks for the info. If I stick my finger in the box I can feel something in the way but there is still a gap to get my finger down the box. I am better off with another box as its on nearly 110k. I can get a 58 plate box for £150 but I am just wondering about the 1.4 boxes. If its a bit shorter then that would be better. Can't find the info on service box though.
Posted: Wed Sep 21, 2011 3:49 pm |
Its not bolted in an MA box its pressed on. Hense why it breaks off!
Posted: Wed Sep 21, 2011 3:50 pm |
is that a 206 box?
you have to make sure it run rod linkage and cable clutch.
Trade Rating: +32
I've got a box you can have for £100.
Done around 40k.
(I'm only in Manchester)
Posted: Wed Sep 21, 2011 4:11 pm |
What engine? I will have to see as I will still need to pay someone £15 petrol; if I find anyone that will get it for me.
Posted: Wed Sep 21, 2011 4:13 pm |
imjeeves wrote: |
Its not bolted in an MA box its pressed on. Hense why it breaks off! | didn't know that
Posted: Wed Sep 21, 2011 4:30 pm |
Trade Rating: +32
Think it's a 1.1 but not 100% without looking.
Posted: Wed Sep 21, 2011 4:49 pm |
well check for me when you get a chance. Still looking into a 1.4 box but can't find any details
Posted: Wed Sep 21, 2011 5:16 pm |
