Online Now [391]:
Visitors: 390
Today: 35982
Total: 105364472
Forums › The Car › 206 Problems › Oh dear, gearbox help :(
Go to page Previous  1, 2
Matt
PostPosted: Thu Sep 22, 2011 1:09 am Up
Trade Rating: +32
Afaik, any box will fit. As long as you get the cable/hydraulic aspect correct to your car.
Only difference will be the gear ratio's.
Rob2859
PostPosted: Thu Sep 22, 2011 5:52 am Up
That sounds promising. I found this:
www.ebay.co.uk/itm/300..._500wt_898
I need to find out if its got a cable clutch now which it probably will do.
PostPosted: Sun Sep 25, 2011 6:01 am Up
no idea at all; better check on the servicebox as i remember most RHD 206 run hydraulic clutch....
shaft
PostPosted: Sun Sep 25, 2011 1:53 pm Up
The box in your link is definately a cable clutch type. You can see the actuator arm in the photo.
HTH,
Nick.
Man make? ------ Man fix!
Rob2859
PostPosted: Sun Sep 25, 2011 3:38 pm Up
Thank you but I already found my answer. I don't know a great deal about gearboxes. The S2 gearbox can also be found on the 206 XS. Why does the 1.6 have such a short ratio? Also how much difference is it going to make to acceleration and drive-ability? I am stuck between this box (on about 80k) and a 58 plate box with lower miles.
Page 2 of 2
