Online Now [711]:
Visitors: 710
Today: 74751
Total: 146973259
Forums › The Car › 206 Talk › Remove/Replace Boot/tailgate?
Forum Index › 206 Talk
acotton21
PostPosted: Thu Sep 22, 2011 3:43 am Up
Getting a new boot for my car as the colour on mine is fading a little and with all the wires and that how do you go about removing and replacing it?
PostPosted: Thu Sep 22, 2011 4:16 am Up
I think the harness connection block is near the back light. Disconnect it and pull up through the rear pillar to the roof line, then feed it through so it is out of the vehicle. Disconnect the rear wash/wipe water supply tube. Undo the lifting struts and get a mate to help hold the tailgate steady, finally undo the bolts holding the tailgate to the main body.
To refit, just do it in reverse.
jimjam19927
PostPosted: Thu Sep 22, 2011 4:17 am Up
easy to do but would recommend to be a two man job.
I just cut the wires and re wired them with bullet connectors.
Just look for the nuts holding it on and undo Smile
Member: 685
I Over Use Smilies Razz
jimjam19927
PostPosted: Thu Sep 22, 2011 5:29 am Up
tbh mate its pretty simple Just give it a go. If you can read and right you can change a tailgate.
Member: 685
PostPosted: Thu Sep 22, 2011 8:04 am Up
BODGE Rolling Eyes
Peugeot wasted there time fitting that multi plug connector for the tailgate wiring then Wink
acotton21
PostPosted: Thu Sep 22, 2011 8:21 am Up
MrBSI wrote:
BODGE Rolling Eyes
Do you think a garage or body shop would fit it as i didnt real fancy cutting wires
PostPosted: Thu Sep 22, 2011 10:21 am Up
acotton21 wrote:
MrBSI wrote:
BODGE Rolling Eyes
You DON'T cut wires, there's a connector plug behind the trim panel in the boot for the tailgate wiring, unplug it.
