Latest: Kifi69
Overall: 17183
Online Now [485]:
Visitors: 484
Today: 174778
Total: 144014744
Forums › The Car › 206 Talk › Worried about HGF
Worried about HGF
LogBookLarry
PostPosted: Thu Sep 22, 2011 10:42 am Up
Evening all. Got a 1.4 206 with 60.000 v reg.
Had an oil leek on the rocker cover gasket which driped onto me alternator belt, which then led (or maybe made) to the belt slipping off, so i replaced the belt and changed rocker cover gasket....all seems fine and dandy.
Untill the there is another oil leek, took rocker back off and iv noticed that there is an oil leek coming from me head gasket area :S
just to check i tried tightning the 4 bolts there and i got at least 1/2 turn out all of them!!!! which has got me thinking has a previous owner done a bodge job on the head gasket and used the bloody same bolts!!!
am i looking at a future head gasket failure?
tar
Larry the Log Book keeper Smile
Speeding doesnt kill you. Suddenly becoming stationary, thats what gets you....
PostPosted: Thu Sep 22, 2011 11:13 am Up
It's about the correct torque, not turns. I'd check them properly incase you've over tightened them.
LogBookLarry
PostPosted: Thu Sep 22, 2011 11:16 am Up
yes sorry it was torque, and half a turn to the correct torque. Once you re-do the head iv always tighted the head bolts, then after 100 miles re-tighten.
Im thinking either he hasnt done the 2nd check or reused the bolts
LogBookLarry
PostPosted: Thu Sep 22, 2011 11:18 am Up
also, with me doing this the oil leek as virtually stopped...but still worried about the head
PostPosted: Thu Sep 22, 2011 11:28 am Up
As long as the cars running alright, ie temp ok, water & oil levels ok & no 'mayonnaising' on the filler cap I woudn't think you had anymore need to worry than normal.
LogBookLarry
PostPosted: Thu Sep 22, 2011 12:11 pm Up
cheers matey, i wasnt 100% sure.
