Latest: SA01
Overall: 17138
Online Now [1681]:
Visitors: 1680
Today: 38451
Total: 111352847
Forums › The Car › 206 Talk › Peugeot 206 CC
Peugeot 206 CC
Go to page Previous  1, 2
welsh_ben
PostPosted: Thu Sep 22, 2011 5:28 am Up
Cheers but going to get old bracket scrubbed up and re-welded on. Alot cheaper than £50 box plus need it fixed by weekend. Cheers for the link. Will see if anywhere local has that
hello
PostPosted: Thu Sep 22, 2011 12:10 pm Up
gazza82 wrote:
glenpring wrote:
can you put a cage under the car like a normal 206 hatchback?
Probably not. The CC has strengthening bars which attach to a box-like structure underneath the boot floor. That's exactly where the spare would need to go.
gazza82
PostPosted: Fri Sep 23, 2011 1:15 pm Up
Don't look like that after 10 years ... Wink
welsh_ben
PostPosted: Sun Nov 20, 2011 3:09 pm Up
new problem
for some reason the car on idle seems to act as if its "shivering" revs drop a bit then go back up for a few seconds then drop again...this is when the misses drives but ive noticed when i drive i like to use the rev band and it dont shiver on idle so its making be think that it shivers when the car is cold? (no pun intended)
hello
welsh_ben
PostPosted: Sun Dec 04, 2011 8:03 am Up
anyone?
hello
gazza82
PostPosted: Sun Dec 04, 2011 10:10 am Up
The only way to find out is put it on a diagnostic system and see if it's recorded any faults. Not all put ethe engine mgmt light on.
It sound a bit like a coil pack starting to fail, but without checking you just start throwing money on parts which may or may not be the problem.
PS Did you get the exhaust bracket rewelded?
Page 2 of 2
