Online Now [67]:
Visitors: 66
Today: 11848
Total: 105246679
Forums › The Car › 206 Problems › Really Rattley Radiator
Debz
PostPosted: Fri Sep 23, 2011 11:38 pm Up
Hi Guys
Not sure if its a common problem, or maybe im missing a bolt or something, but my radiator will not stop rattling when Im taking off. I did think it was the Pipeacross filter, so cable tied that down, but its still doing it. Should I just try and just cable tie that down to lol ??? Or just get a man to look at it lol???
Cheers
My Name is Debora and Im a member of Nerdz-anonomus haha
ukskater01
PostPosted: Sat Sep 24, 2011 1:50 am Up
If your not sure get a mechanic to look at it, but before you do check everything's tight. Are you sure it's your radiator? My fan used to do this but would only rattle when it turned on. Changed fan problem solved Smile
Debz
PostPosted: Sat Sep 24, 2011 2:19 am Up
Ye I had a quick look under the bonnet when checking the air filter, and the radiator did feel lose, and when something rattles it does feel like its the whole front of the car, its hard to explain unless u hear/feel it. I will double check the fan in case tho.
Thank You x
Debz
PostPosted: Sun Oct 02, 2011 3:45 am Up
Its still doing it and boyfriend is determined its not the radiator, but its when I pull off as if its vibrating, Im going to force him to look at it today after his playstation time this morning, is there anything you guys can think of that he should be looking for / at ?? x
PostPosted: Sun Oct 02, 2011 4:08 am Up
Debz wrote:
Hi Guys
Cheers
Is your 206 Chitty Chitty Bang Bang, so it flys? Laughing
Debz
PostPosted: Sun Oct 02, 2011 4:12 am Up
Thanks Lee, your funny, but that doesnt help one bit lol x
PostPosted: Sun Oct 02, 2011 4:15 am Up
Jack the front end of the car up and drive it whilst someone is looking in the bonnet...that way you'll be able to cancel out that the engine is doing it....then your are looking for something that moves when you hit bumps.
Debz
PostPosted: Sun Oct 02, 2011 4:17 am Up
Easier said than done but the sounds of it lol
Will have ago at that later on then, see what we can find x
PostPosted: Sun Oct 02, 2011 4:22 am Up
Nah it's easy, just stick the front end on axle stands Smile
Debz
PostPosted: Sun Oct 02, 2011 4:24 am Up
Ok will have ago later and let you know how well or bad it turns out lol x
Debz
PostPosted: Fri Nov 04, 2011 1:22 am Up
guys ive solved the rattling problem, it was my shock obsorber, the bolt had snapped and was just making a banging noise when i went over the smallest bumps, but Lee has come to my rescue lol xx
PostPosted: Fri Nov 04, 2011 5:13 am Up
Get it fitted in the end then? Smile
Debz
PostPosted: Sat Nov 05, 2011 2:06 am Up
didnt know anyone with clamps so its booked into garage wednesday with te MOT x
