Online Now [217]:
Visitors: 216
Today: 3752
Total: 105980911
Forums › The Car › 206 Problems › randomly loses power then fixes itself !
Go to page Previous  1, 2
PugJH
PostPosted: Thu Jul 14, 2011 9:08 am Up
I think Kersh is talking about the Clutch release bearing, worth a look, but 1st a new ICV as they are cheaper.
But Kersh seems closer to the problem than i was, because as he said ICV would affect it while driving.
EDIT:
Yes by all means check the Airflow, check the pipe from filter box to the engine, see if its squashed anywhere, my xsi's was and i could see the needle go up fall back down a bit then go back up again, maybe its that Very Happy
WIP: Black 1.6 16v XSi
Beauté Noire
Kersh
PostPosted: Thu Jul 14, 2011 9:15 am Up
if youre checking for an air leak, run the engine and lightly spray wd40 around all the gaskets and seals where a leak could be. if there is a change in engine noise in any way then the wd40 is getting into the system and you have a leak
Member number: 36
smallzoo
PostPosted: Thu Jul 14, 2011 3:36 pm Up
If it was the clutch.. just as a very approx estimate at an independent garage ( say £30/hr ) how much do you think it would cost labour plus materials to fit a new clutch ?
Cheers
Pete
PostPosted: Thu Jul 14, 2011 3:38 pm Up
5 hours + clutch (around 100)
PugJH
PostPosted: Fri Jul 15, 2011 12:14 am Up
but be prepared to pay upto £300 if they include the clutch.
Beauté Noire
Amrpug
PostPosted: Sun Sep 25, 2011 5:11 pm Up
Hi smallzoo
Did you fix this I think my 206 has a very similar problem.
Any help would be greatly appreciated as the garage I go to seem baffled.
AMRPUG
Page 2 of 2
