Posted: Sun Sep 25, 2011 11:31 am |
In my old 1.9d I got about 50 litres of fuel from near empty, but on my 1.4, 06 plate I'm getting about 40 litres in (from near empty) before I can't put anymore in. The gauge also isn't showing that the tank is full; the highest it'll go to is about halfway between the first quarter of the gauge. Any suggestions as to why this may be?
Posted: Sun Sep 25, 2011 11:33 am |
If the fuel pump is cutting off when you are filling up, then it's the gauge that's faulty not your tank
Posted: Sun Sep 25, 2011 11:42 am |
when did you notice it? like.. was this after you changed something?
| Peugeot 206 Zest 1.1 5 door | |
Posted: Sun Sep 25, 2011 12:06 pm |
Must be a hole or summot
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
Posted: Sun Sep 25, 2011 2:16 pm |
Lee wrote: |
If the fuel pump is cutting off when you are filling up, then it's the gauge that's faulty not your tank  |
The pump cuts off when the tank is at capacity but I thought 206's tanks are 50 litres, so every time I fill up the pump is cutting off at 40 litres - 10 below capacity. The gauge seems to be right because it's showing that that 10 litres isn't in the tank, but the pump is cutting off because its nearing capacity
Posted: Sun Sep 25, 2011 2:18 pm |
Deceitful wrote: |
when did you notice it? like.. was this after you changed something? |
Had the car 3 months and it's done it ever since. I've not changed anything on it.
Posted: Sun Sep 25, 2011 2:38 pm |
SteDuval1985 wrote: |
Lee wrote: |
The pump cuts off when the tank is at capacity but I thought 206's tanks are 50 litres, so every time I fill up the pump is cutting off at 40 litres - 10 below capacity. The gauge seems to be right because it's showing that that 10 litres isn't in the tank, but the pump is cutting off because its nearing capacity  |
When the fuel light is on, how much fuel does it take to fill it up?
Posted: Sun Sep 25, 2011 3:31 pm |
40 litres or so. Today I'd driven about 20 miles on the fuel light before I filled up. I think the manual says you have 30 miles or so left in the tank at that point so I presumed that the tank was nearly empty. I got 40.8 litres in until I couldn't get any more in.
Posted: Sun Sep 25, 2011 3:47 pm |
When the fuel light comes on you have a gallon left
Posted: Mon Sep 26, 2011 12:30 pm |
I can still only get 40 litres in and the gauge isn't reaching the top, even though the tank is meant to be 'full'.
Posted: Mon Sep 26, 2011 12:34 pm |
BSI reboot would be my first port of call
