Posted: Tue Sep 27, 2011 2:03 pm |
I'd bet the MAF
What engine is it?
Posted: Tue Sep 27, 2011 2:08 pm |
On me freelander you can disconnect the maf when it's faulty and the car will run on default settings letting you still drive ok whilst you pick up a new one........dunno if you can do this on the 206 though?
Posted: Tue Sep 27, 2011 2:11 pm |
mjrimmer wrote: |
On me freelander you can disconnect the maf when it's faulty and the car will run on default settings letting you still drive ok whilst you pick up a new one........dunno if you can do this on the 206 though? |
No
Posted: Tue Sep 27, 2011 2:15 pm |
Bugger! who'd of believed landrover made something easy and cheap to test ( everything else costs the earth mind you).
Posted: Tue Sep 27, 2011 2:29 pm |
1.4 8v, Dont think it would be MAF but if a reset of the ECU (disconnecting battery) didnt kick start it out of 'limp mode' then diagnostics is the only route right?
Posted: Wed Sep 28, 2011 2:46 am |
Hi all
Sorry for double post again haha
Started car this morning - works fine! Revs freely, all sorted. Take it to a Peugeot garage who say the earliest they'll be able to chip it is next Monday. Then as I'm leaving the garage to go to work, it kicks in again. Ultimate fail. Disconnected battery in an attempt to get her working again. Gutted
Mike
Posted: Wed Sep 28, 2011 2:51 am |
Does it stutter a lot? Could be a coil pack.
Posted: Wed Sep 28, 2011 2:57 am |
It only stutters when it hits the rev range for limp mode,
When i started it this morning it was fine, however since back in limp mode it had a stress at 3k, thats all thats wrong with it i think.
