Online Now [242]:
Visitors: 241
Today: 75499
Total: 143065559
Forums › The Car › 206 Problems › Steering wheel judder
QuArTz
PostPosted: Wed Sep 28, 2011 10:34 am Up
Trade Rating: +16
Recently, in the last 2-3 days when I have been turning around corners the steering wheel shakes and judders.
In a straight line the car is fine but also when stationary, with engine running, when I turn the wheel it judders through the wheel and steering wheel.
You can actually see the shaking/juddering when I turn the wheel and watch it from behind the door.
This happens from the moment I turn the wheel to full lock.
Any ideas what this might be?
AshH
PostPosted: Wed Sep 28, 2011 10:36 am Up
Ball joint? Would say tracking but if its not happening in a straight line / ... But try Ball Joint mate!
Team - 180
Team - ATM!!!
macj
PostPosted: Wed Sep 28, 2011 10:46 am Up
Check your power steering fluid level
QuArTz
PostPosted: Thu Sep 29, 2011 2:17 am Up
Trade Rating: +16
The tracking is waaay out, It pulls to the right so much it steers round corners its self.
Im taking it to be tracked tomorrow, hopefully that will fix it.
Thanks for the info
QuArTz
PostPosted: Thu Sep 29, 2011 2:19 am Up
Trade Rating: +16
If the power steering fluid is low enough to cause this problem, would that suggest there is a leak?
mjrimmer
PostPosted: Thu Sep 29, 2011 7:50 am Up
Check the pwer steering pump belt is under the correct tension and not worn.
206 gti 180
