Online Now [261]:
Visitors: 260
Today: 65033
Total: 142209183
Forums › The Car › 206 Problems › Tail light problem .
hooliganchild46
PostPosted: Fri Sep 30, 2011 12:36 pm Up
So I am having a little trouble with my tail lights . I have changed all the bulbs and my tail bulbs and brake bulbs keep stop working . The most recent time even the high level brake light has stoped working and I checked the fuses and changed the one broken fuse . Can someone shed some light on this for me please ?
-Dave-
PostPosted: Fri Sep 30, 2011 12:43 pm Up
Trade Rating: +36
Connector under the passenger footwell?
Ex 206 Owner.
PostPosted: Fri Sep 30, 2011 12:48 pm Up
Short circuit...lose wire.
If your 3rd brake light isn't working then either your passenger brake light isn't working as well or there is a lose/snapped wire
hooliganchild46
PostPosted: Sat Oct 01, 2011 12:26 am Up
Thanks guys , I'll take a closer look today .
hooliganchild46
PostPosted: Sun Nov 20, 2011 7:09 pm Up
Hello matey , where under the passanger footwell is the connector . I wanna have one last poke at it before sending her in to a auto elec .
scotty79
PostPosted: Mon Nov 21, 2011 2:15 am Up
there's a connector under the glovebox, if he's talkin about that one then it's more to the right hand side if your sittin on the seat, simple case of pushin it back in but anytime this has happened with me the brake lights have stayed on constantly
hooliganchild46
PostPosted: Mon Nov 21, 2011 10:14 am Up
Yeah you see with my problem only the right brake light is working . I will give it a try anyway .
hooliganchild46
PostPosted: Wed Nov 23, 2011 5:46 am Up
Well I had nother look at the connecter and every thing looks fine . The only other thing I can think of is the brake light switch but I have no idea where that would be ( maybe behind pedal ) or there is fuse box fault .
scotty79
PostPosted: Wed Nov 23, 2011 6:43 am Up
the connector under the glove box is where the pedal switch or pad is, if you put your hand along a bit you can feel a metal rod that comes from the pedal, basically you push the brake pedal the rod pushes against a pad/switch after a while this pad/switch gets pushed away and the connection isn't made properly and needs to be pushed back into position
