Online Now [382]:
Visitors: 381
Today: 134410
Total: 144954577
Forums › The Car › 206 Talk › air con fault
air con fault
Forum Index › 206 Talk
Enforcer
PostPosted: Fri Sep 30, 2011 1:07 pm Up
just bought a 5 door in silver,26000 miles,2005.When you switch the air con on the little green light lights up but no cool air.I have not checked whether it needs gassing up,but as only low miles did not think that to be the problem.Could it be the clutch mechanism on the pump,is there an easy fix(remove a shim ?)or has anyone on here got any thoughts on the subject
Enforcer
PostPosted: Fri Sep 30, 2011 1:11 pm Up
It will want regassing.
No or low gas in system = pressure safety switch stops the compressor switching on.
brad-morris
PostPosted: Fri Sep 30, 2011 1:17 pm Up
This weather were having is when all my call outs start haha bring on the WINTER!!
Enforcer
PostPosted: Fri Sep 30, 2011 1:37 pm Up
Thanks for info Brad, its not on the road yet, I dont need it until December but I am trying to get every thing spot on before it goes on the road. Its a really clean and tidy car. Me and a friend have serviced every thing you can and wax oiled every thing you can see,lol This is the last thing to put right apart from a new engine tray which should arrive next week as the other one is damaged.
Its not taxed or insured so cant take to have gas put in the air con yet
Thanks again
Enforcer
brad-morris
PostPosted: Fri Sep 30, 2011 1:40 pm Up
Make sure they pressure test it, and when the air con system is vacced out it holds its vac for 10 mins. otherwise the gas will just leak back out.
i had that trouble luckily there's a garage down the road so they picked it up for me to get it through its MOT
Enforcer
PostPosted: Fri Sep 30, 2011 3:06 pm Up
Will do mate thanks for the tip.
Enforcer
Mrs_Howey
PostPosted: Fri Sep 30, 2011 3:16 pm Up
Re-gassing is the cheapest option, i thought my compressor had gone, but after a free re-gas i found that i have a massive leak in the system Smile
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
puggy206
PostPosted: Fri Sep 30, 2011 5:06 pm Up
my first pug had a masive air con leak and im so glad i got my new one now. the aircon runs like a dream im as cold as ice in it. but when i get out it feels even warmer Sad
Citroen DS3
D-style +
1.6 VTI
pug-206-boy
PostPosted: Fri Sep 30, 2011 8:22 pm Up
Never used my air-con in the 4 years I had my old 206, wastes fuel, can't be having that.
PostPosted: Sat Oct 01, 2011 5:08 am Up
Rolling Eyes
Thats 100% total b******s.
Air con uses LESS fuel then driving with the windows open Wink
Coolspot
PostPosted: Sat Oct 01, 2011 9:17 am Up
My aircon has stopped working twice but i have been told it was due to the wife not using it enough. If at all.
She says i uses up fuel but study show that at a low speed have windows open and at higher speeds use the aircon.
Systems are so efficient that you won't really notice the the difference on fuel using aircon anyway.
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
PostPosted: Sat Oct 01, 2011 9:19 am Up
Aircon is use it or lose it.
It uses hardly if anymore fuel than normal.
Get it regassed
PostPosted: Sat Oct 01, 2011 10:59 am Up
Air conditioning is there for added comfort so there will be a small (tiny) cost in running it.
Would you sit on a deck chair instead of an armchair just because it's cheaper?
