Latest: S2cgm
Overall: 17178
Online Now [118]:
Visitors: 117
Today: 33907
Total: 137100977
Forums › The Car › 206 Talk › can u adjust a clutch?
20619d
PostPosted: Mon Oct 03, 2011 5:24 am Up
is so how do u do it as my pedel is higher now and now doin more miles in car it a pain can i make it sit lower down so nicer to drive with?
PostPosted: Mon Oct 03, 2011 7:19 am Up
I know exactly what you mean mate.
All 206 have an auto-adjusting clutch cable mechanism, so you cannot adjust it as such.
I recently replaced the whole clutch set and cable due to it being very stiff and having a sensitive
left knee. Best money I've ever spent on the pug..
(The springs go stiff over time due to metal fatigue.)
However some models have a hydraulic clutch system which I know nothing about.
PostPosted: Mon Oct 03, 2011 7:33 am Up
Just change the clutch cable, only about £20. If it makes a difference then brilliant but if not then it doesnt matter.
+1
PostPosted: Mon Oct 03, 2011 7:54 am Up
Will be a hydraulic clutch on the OP's 206
Have fun trying to locate that non existent clutch cable Rolling On The Floor Laughing
PostPosted: Mon Oct 03, 2011 8:41 am Up
Any info?
Mr_Cellexe
PostPosted: Mon Oct 03, 2011 9:17 am Up
how did you get the pedal higher?
not sure ive ever seen a way to adjust it, although my best guess would be on the master cylinders somewhere.
greg.mitchell350
PostPosted: Mon Oct 03, 2011 12:33 pm Up
it will be hydraulic which has no adjustment. if the pedal is getting higher then i would guess at the clutch starting to wear out
206 enthusiast
