Online Now [137]:
Visitors: 135
Bots: 2
Today: 21629
Total: 138643539
Forums › The Car › 206 Talk › wheels spacers
wheels spacers
Jgti
PostPosted: Mon Oct 03, 2011 9:32 am Up
This has Been asked many times before am sure but am crap as searching fourms
just woundering whats the best size spacers to get on a X reg gti with sp archs on the standard nimrod wheels
any issues or problems which these above a size etc
cheers
Jase
Just Living Life
EuroPeugeot
PostPosted: Mon Oct 03, 2011 9:36 am Up
I had 20mm spacers on the rear with 16" nimrods with 195/40/16 tyres. It was lowered so the tyres JUST about sat in the arch and is JUST about scraped when going over a bump or cornering fast.
So depenind on how low your suspension is what tyres and wheel sizes you have, 15mm should be fine
You can also get the rear arches 'rolled' or even do a DIY job if you're up for it
Jgti
PostPosted: Mon Oct 03, 2011 9:44 am Up
its due to be sat on the 16" wheels just so the bottom of the arch will be level with the top of the trye but i have coilovers so fairly firm car looking for spacers there enough to look for but was having problems finding the standard peugeot longer wheel bolts
Just Living Life
EuroPeugeot
PostPosted: Mon Oct 03, 2011 9:57 am Up
15mm then mate
Jgti
PostPosted: Mon Oct 03, 2011 11:10 am Up
where is the best place for longer wheel bolts to use with wheel spacers as because the standard wheel bolt are flat seated its hard to find ?
Just Living Life
char_x
PostPosted: Tue Oct 04, 2011 7:54 am Up
Ebay Smile
Mattie-RS
PostPosted: Tue Oct 04, 2011 7:58 am Up
Search Harder?
Big_Rich180
PostPosted: Tue Oct 04, 2011 8:01 am Up
Mattie-RS wrote:
Search Harder?
He means he cant be arsed to search.
Jgti
PostPosted: Tue Oct 04, 2011 9:38 am Up
ha ha know i mean from what i searched the info and photo's provided look nothing like the bolts for the standard wheels as the standard bolts and flat set where as most other cars have tapered bolts to seat in the bowl of the alloy
Just Living Life
