Latest: Kifi69
Overall: 17183
Online Now [381]:
Visitors: 380
Today: 80800
Total: 144901056
Forums › The Car › 206 Problems › Driveshaft is too long?
shr3k1989
PostPosted: Tue Oct 04, 2011 5:52 am Up
Hey guys,
Just registered so apologies for getting right to the point.
I bought a 206 2 days ago with a gear oil leak quite cheap.
I thought it would be a simple case of changing the oil seal but it now turns out the passenger driveshaft seams too long.
The previous owner said he replaced the gearbox last week with a 1.4s gearbox however the driveshafts according to my local parts and Peugeot are the same?
Sliding the driveshaft into the n/s leaves it about 1/2 inch out and obviously means no seal against the gear oil seal. Driveshafts across the 206 range seam to be the same part number so any advice is much welcomed!
Shr3k
PostPosted: Tue Oct 04, 2011 8:10 am Up
Help if we knew what engine yours was
shr3k1989
PostPosted: Tue Oct 04, 2011 8:26 am Up
Mines a 1.4 8v, apparently the new box also came from a 1.4 8v, but the driveshaft on mine the spline seams too long, seams to be stopping on a pin or something in the box, just the passenger side though, drivers is fine
Shr3k
PostPosted: Tue Oct 04, 2011 8:29 am Up
Nah they should be the same
shr3k1989
PostPosted: Tue Oct 04, 2011 8:43 am Up
Do you think there might be a problem with the gearbox then? There seams to be a pin or something stopping the driveshaft going right the way in?
Shr3k
shr3k1989
PostPosted: Tue Oct 04, 2011 9:27 am Up
Well I decided to order the driveshaft from the car that had the gearbox in, so we will hopefully see what happens friday :/
Shr3k
mjrimmer
PostPosted: Tue Oct 04, 2011 10:49 am Up
Has the end of the splines on the driveshaft got a groove going around it with a spring clip in it?
206 gti 180
macj
PostPosted: Tue Oct 04, 2011 11:03 am Up
The shaft has not gone in all the way.... needs a nudge Wink
shr3k1989
PostPosted: Tue Oct 04, 2011 11:13 am Up
We used a hammer but it just didnt want to go in, looking in the hole there seams to be a pin or something so ordered the driveshaft that was in there before,
Shr3k
macj
PostPosted: Tue Oct 04, 2011 11:17 am Up
The pin you can see is in the diff..... it should fit if its all standard pug stuff
shr3k1989
PostPosted: Tue Oct 04, 2011 11:19 am Up
Well we went from a 1.4 8v gearbox to another 1.4 8v gearbox and in the process the driveshaft on the passenger side just will not fit, had it at my mates garage so would assume if there was a certain way of fitting it he would have known
Shr3k
macj
PostPosted: Tue Oct 04, 2011 11:24 am Up
Its one of those situations where you need to see it to advise..... Confused
shr3k1989
PostPosted: Tue Oct 04, 2011 11:27 am Up
Well it's been put back together for now but when the new driveshaft arrives Friday/Saturday I'll get photos if it doesnt fit!
Shr3k
greg.mitchell350
PostPosted: Tue Oct 04, 2011 12:16 pm Up
so are the driveshafts genuine?! can only assume that is the problem, if the gearbox is the exact same the shaft should be the problem. like 'macj' said though, really need to see to advice
206 enthusiast
shr3k1989
PostPosted: Tue Oct 04, 2011 12:22 pm Up
Yeah I understand, I will get some photos,
The car was running fine, had a 1.4 8v gearbox but the box went, so got a replacement gearbox from a 1.4 8v. Fitted it, drivers driveshaft went in find but the passenger one doesn't go right in.
The car drives, but the shaft doesn't go in far enough to make the oil seal so I loose gear oil. There seams to be that pin stopping the driveshaft going right in yet the old gearbox didnt have this :/
Shr3k
