Latest: Stu-mill
Overall: 17131
Online Now [266]:
Visitors: 266
Today: 13460
Total: 104699096
Forums › The Car › 206 Problems › Driveshaft is too long?
Go to page Previous  1, 2
greg.mitchell350
PostPosted: Tue Oct 04, 2011 12:29 pm Up
that pin is part of the differential and the reason for the old gearbox not having one might be because that is what caused it to fail? does the gearbox have slight variations depending on the year of the car?
206 enthusiast
shr3k1989
PostPosted: Tue Oct 04, 2011 12:35 pm Up
No I have been told the gearboxes are the same. So the pin may still be in the end of this gearbox hence it not fitting?
Shr3k
greg.mitchell350
PostPosted: Tue Oct 04, 2011 12:52 pm Up
the pin should be in there, at a guess, really need to see it. could be thinking of different pins
206 enthusiast
shr3k1989
PostPosted: Tue Oct 04, 2011 4:06 pm Up
Ok thanks for your help, I am getting the driveshaft that was in this box on Friday so I will know more then, will take some photos if I am still having problems.
Shr3k
Rob2859
PostPosted: Tue Oct 04, 2011 6:01 pm Up
I have been told the shafts can be different. I was speaking to a gearbox re-conditioners and they said some of the shafts are half an inch longer on the spline.
greg.mitchell350
PostPosted: Wed Oct 05, 2011 3:37 pm Up
are those genuine shafts that can be longer or patend parts?
206 enthusiast
shr3k1989
PostPosted: Thu Oct 06, 2011 1:00 pm Up
Well I tracked down where the gear box came from and asked for the driveshaft aswell. They sent it yesterday and it definately is smaller. Will check tomorrow but god knows which gearbox I have fitted!!!
Shr3k
PostPosted: Thu Oct 06, 2011 1:35 pm Up
could it be a 106/ saxo box?
greg.mitchell350
PostPosted: Fri Oct 07, 2011 5:39 pm Up
i know 106's use to have different length driveshafts because they had different depth hub nuts depending on the shaft so might be the same case with the 206's
206 enthusiast
Page 2 of 2
