Posted: Tue Oct 04, 2011 8:13 am |
I am currently having a problem tracking down any breakers yards or people who are breaking a GT so i can get the cabin loom for the folding mirrors. I have got them cheap with the door loom but because the connections are different i cant just plug the mirrors into my exisitng wiring on my multiplex XSI.
Is there any way of getting an apadter to fit my existing door loom to the mirror.
Posted: Tue Oct 04, 2011 9:31 am |
You can hard wire them. Pretty sure someone wrote a guide on how to. Or you could PM Lee.
Posted: Tue Oct 04, 2011 12:27 pm |
Go to Peugeot, they sell the wring adapter. This was covered recently, so have a quick search. Lee or Mr.BSI will give you the part number. Its now much.
I rewired my own, it wasnt hard.
Posted: Tue Oct 04, 2011 1:00 pm |
| CD-B3 wrote: |
| You can hard wire them. Pretty sure someone wrote a guide on how to. Or you could PM Lee. |
Already told him that about 5 times
Posted: Wed Oct 05, 2011 5:10 am |
| Steve206 wrote: |
I rewired my own, it wasnt hard. |
Lee you have the part number for the adapters please buddy.
Posted: Wed Oct 05, 2011 5:37 am |
I have 9 wires going into the adapter at the top of the door on both passanger and drivers side so im guessing all i need is an adapter to connect them to the folding mirrors from the GT because it looks as if it is already wired in.
| 206, Flamenco Red, 54 Plate, 2.0 HDI | |
Posted: Wed Oct 05, 2011 9:14 am |
Are the connectors the same on the mirrors?
Posted: Wed Oct 05, 2011 9:40 am |
| Mark! wrote: |
| I have 9 wires going into the adapter at the top of the door on both passanger and drivers side so im guessing all i need is an adapter to connect them to the folding mirrors from the GT because it looks as if it is already wired in. |
You have the wiring already, I just guess you have the wrong type connector plugs.
The pin numbers in the mirror connector plug match up with the pin numbers on the door loom connector plugs.
Posted: Wed Oct 05, 2011 11:38 am |
| Lee wrote: |
| Are the connectors the same on the mirrors? |
Nope thats the only issue i have. I need the multiplex connector on the mirrors so i can plug them into the existing door looms.
Posted: Wed Oct 05, 2011 12:11 pm |
Just cut the connectors off and use crimps, or solder + heat shrink
Posted: Wed Oct 05, 2011 12:18 pm |
| Lee wrote: |
| Just cut the connectors off and use crimps, or solder + heat shrink |
Was just a little dubious about doing that till i seen them working if you know i mean lol
Can you buy the connector from peugeot for the mirror because then i can just snip tht one and change that
Posted: Wed Oct 05, 2011 12:20 pm |
What are you wanting? 3x3 or 2x5?
Posted: Wed Oct 05, 2011 12:30 pm |
2x5
Posted: Wed Oct 05, 2011 12:33 pm |
| Mark! wrote: |
2x5  |
Peugeot do an official adaptor loom to go from white plug to brown plug
There nearly £60 each!
Posted: Wed Oct 05, 2011 12:39 pm |
| MrBSI wrote: |
| Mark! wrote: |
2x5  |
There nearly £60 each!  |
Geeeeez! I only need 10cm worth of adapted loom ha! Robin B**S***D*!
