Online Now [1127]:
Visitors: 1126
Today: 83996
Total: 146538928
Forums › The Car › 206 Talk › Angel Eyes Query
Angel Eyes Query
Forum Index › 206 Talk
kakaruto
PostPosted: Fri Oct 07, 2011 3:00 am Up
Hello i was just wondering about the side light issue
basically i have a set of angel eyes and i dont have the bulb holder or bulb for the sidelights and i tried fitting my side light bulbs and bulb holder from my ph1 head lights, the bulb holder fits but the connector will not connect onto it so i was wondering if the angel eyes will be ok for the side lights only or do i need them side light bulbs as well?
if i do can anyone guide me as to where i can buy them from?
thanks again
Rob
2001 Y 206 1.4 LX Black
tim30485
PostPosted: Fri Oct 07, 2011 3:16 am Up
you could use a scotch lock connector and wire to the bulb holder?
Drive Smarter Not Faster!
kakaruto
PostPosted: Fri Oct 07, 2011 3:42 am Up
what is one of them? lol
banboots
PostPosted: Fri Oct 07, 2011 3:47 am Up
Its a little blue plastic clip with a W shaped piece of metal inside you crush onto 2 wires to make a connection available from any auto shop
Have a nice day!
coopskin
PostPosted: Fri Oct 07, 2011 4:18 am Up
Trade Rating: +13
your halos are fine as sidelights
kakaruto
PostPosted: Fri Oct 07, 2011 4:45 am Up
i get you now, used one of them so i can feed off the remote wire for amp, never knew it was called a scotch lock, i could use one of them i suppose but i find it to be a bodge only problem.
Are you sure halo's are fine as a side light? i just dont want to take it to a MOT station come april to find it will fail for no side light bulb lol.
tim30485
PostPosted: Fri Oct 07, 2011 5:07 am Up
i like the look of the light unit when the side lights are on with the halos, i'd scotch lock up, the joy of these is you can remove them if no longer required and you've not had to actually cut your wiring
kakaruto
PostPosted: Fri Oct 07, 2011 5:16 am Up
umm will do just need to find the time to do it now lol
tim30485
PostPosted: Fri Oct 07, 2011 5:39 am Up
wont take long lol
