Latest: Beduff1977
Overall: 17134
Online Now [1570]:
Visitors: 1569
Today: 76859
Total: 107257665
Forums › The Car › 206 Talk › want would be cheaper?
20619d
PostPosted: Sat Oct 08, 2011 1:26 am Up
my mate has put this on his facebook and asked if i can post on here to see wot people think.
right passenger drive shaft is goin possible gearbox probably clutch starter motor and a strange knocking from the cam belt .... is it cheaper to just drop the gti lump in and how much work is involved
PostPosted: Sat Oct 08, 2011 2:12 am Up
I don't know.
PostPosted: Sat Oct 08, 2011 2:47 am Up
They are strange things to happen all at once
Don't even know what car he has, so how we supposed to know if it's cheaper
AshH
PostPosted: Sat Oct 08, 2011 2:48 am Up
Would help if we new model, current engine size ... So on?
Team - 180
Team - ATM!!!
craigy00craig
PostPosted: Sat Oct 08, 2011 3:35 am Up
Sounds f****d whatever it is, buy a new car
Progress Threads:
PostPosted: Sat Oct 08, 2011 5:08 am Up
Is the car left or right hand drive? Is that right as you sit in the drivers seat or as you stand in front of the car looking at it? Or has the car got 2 drive shafts each side? I never knew knowing your left from your right was so complicated till today.
PostPosted: Sat Oct 08, 2011 5:14 am Up
It's p**s poor grammar.
greg.mitchell350
PostPosted: Sat Oct 08, 2011 6:10 am Up
is it cheaper than what!? fixing all the possible faults? depends what u have. if you dont have a gti at present there will be no way it is cheaper, completely different to the 1.6, 1.4 and 1.1 engine. the inlet sits at the front on the gti unlike the other engines. would require new subframe, exhaust, coolant reservoir, radiator, gearbox, ecu, wiring loom, anti roll bar, power steering rack and pipes. and that is just the stuff i can think about of the top of my head!
206 enthusiast
20619d
PostPosted: Sat Oct 08, 2011 6:12 am Up
i just copied and paste wot he put on facebook. it a 1.6 16v xsi. he got car a month ago for £2500.
20619d
PostPosted: Sat Oct 08, 2011 6:22 am Up
yep then fixing all
greg.mitchell350
PostPosted: Sat Oct 08, 2011 6:38 am Up
wll i would of thought the large list of required items along with the labour rate would of be self explanitary and a conversion would be a lot more expensive. but you still havnt mentioned what model it is at the minute
206 enthusiast
2Oh!6
PostPosted: Sat Oct 08, 2011 7:02 am Up
Lol he bought it a month ago and it sounds like it's close to seeing a scrapyard. Must have checked it out good.
VTEC goes BWAAAAAAH! Wink
paul_c
PostPosted: Sat Oct 08, 2011 8:28 am Up
How come the messages need to be relayed via you, can't he join the forum and post in the normal way? Is "the friend" really you, but you're too embarrased to admit it?
macj
PostPosted: Sat Oct 08, 2011 8:44 am Up
You would be better replacing the engine/gearbox with the same size. Less cost and Less hassle
Matt
PostPosted: Sat Oct 08, 2011 8:46 am Up
Trade Rating: +32
no warranty ?
