Posted: Sun Oct 09, 2011 12:28 pm |
Trade Rating: +46
my cars just thrown up anti-pollution again it needs a servive in 5k but oil is black and well over limit, it got cleared over the weekend but came on again earliet after a 4+hour drive...
last check was cat getting old..
Posted: Sun Oct 09, 2011 12:29 pm |
What do you mean by "oil is .... well over limit"?
Posted: Sun Oct 09, 2011 12:31 pm |
i presume you mean your 180....and i am surprise you didn't do the oil on your track car lol
need to check the O2 sensor first...if they are fine then should be a dead cat
paul_c wrote: |
What do you mean by "oil is .... well over limit"? |
over the top of the dip stick?
Posted: Sun Oct 09, 2011 12:42 pm |
Trade Rating: +46
no not the 180, the sw 1,6 16v. it has half pint or more to much. its black and service is due in 5k.. antipollution came on got it checked battery knackerd cat getting old. everything was cleared off, but been on a long drive today and it flashed up again antipolution fault..
monday oil plugs are getting changed dianostics will clear everything off but this seems a common 206 fault..
Posted: Sun Oct 09, 2011 12:46 pm |
Half a litre over shouldn't do permanent damage but it might throw up an excessive amount of oil mist which will enter the air filter area. So have a look at the air filter housing and the filter element, and if mucky clean it all up and change the element. Oil goes black over time, especially on diesels, unless you have some device for measuring the quality of the oil (some dealerships do) you can't really rely on it as more than a basic indication of its age.
Posted: Sun Oct 09, 2011 12:52 pm |
Trade Rating: +46
checked all that put new ait filter on, cars petrol,
Posted: Sun Oct 09, 2011 12:54 pm |
What was the fault code that was cleared off?
Posted: Sun Oct 09, 2011 12:59 pm |
Trade Rating: +46
first of car needed a new battery as it would not hold charge.
FUEL INTAKE SENSOR HIGH
CAT GETTING OLD
