Latest: Kifi69
Overall: 17183
Online Now [633]:
Visitors: 632
Today: 104800
Total: 144396318
Forums › The Car › 206 Problems › Needing some info in Airbags?
Slickrikk
PostPosted: Sun Oct 09, 2011 11:50 am Up
Scotland Area Rep - Slickrikk
Hi, soz not been on for a wile iv been working none stop all month! But a wile back I had a accident in the car. and now I'm looking for the passanger seat airbag and the passanger airbag that is above the door am I right in saying its called the passanger curtan airbag? And also do I have to buy a new airbag modual or can I get a second hand one that didn't have airbag deloyed in it? Then I could get it coded! Any help would be great guys! Cheers
Aegean Blue 206 Gti 180
Pug-Lee-2011
PostPosted: Mon Oct 10, 2011 6:29 am Up
Trade Rating: -1
i wouldnt really go for a second hand module, even though they are normally ok
PostPosted: Mon Oct 10, 2011 6:35 am Up
Second hand will be fine as long as you get the right one.
You could also get the crash data cleared from yours, PM me if you want more info.
You have drivers steering airbag, passengers airbag, drivers and passengers curtain airbags, seat airbags and seat belt pretensioners.
muzkur
PostPosted: Thu Nov 03, 2011 12:10 pm Up
Can I put a airbag system in a car without stock airbags?
Car photographer in Brazil
PostPosted: Thu Nov 03, 2011 12:19 pm Up
You will need the right ECU, and it also turning on in the BSI
Are you wanting to fit a passengers airbag?
PostPosted: Thu Nov 03, 2011 12:22 pm Up
Most likely find it doesnt have any airbags at all being in Brazil, it might have just front seatbelt pretensioners.
PostPosted: Thu Nov 03, 2011 12:23 pm Up
Shipped a few steering wheels over there tho who have asked for the type of airbag connection.
muzkur
If I want to put the passenger one, will need a new dashboard too, right?
So the basic item set will be:
New steering wheel
New dashboard
New ECU
BSI Remap
That's it?
MrBSI, that's right. I forgot the tensioners....
Damn... That will cost a lot.
PostPosted: Thu Nov 03, 2011 12:30 pm Up
If you want the full system you will need Airbag ECU, Steering wheel with airbag, passengers one (the dash might just pop out) seat belt pretensioners and wiring loom and a BSI config
muzkur
PostPosted: Thu Nov 03, 2011 12:32 pm Up
I'll looking for this in totalled cars. Maybe I can buy some parts from wrecked cars. That will help a lot with the final cost.
I'm trying to do the same thing with air conditioning system. That's just what missing in my car: Airbags, AC and ABS...
PostPosted: Thu Nov 03, 2011 12:37 pm Up
Buying from crashed cars is pointless, airbag system will be no good and need replacing.
ABS won't be the easiest thing to fit. I have a ABS pump and master cylinder if you are going ahead with it though.
Also a digital climate control system and AC radiator and compressor.
Airbag's need to come off a un-crashed car. ECU's are cheap enough. Got a couple of airbags if you need them too.
.....infact what year is the car? non-plexed or multiplexed?
muzkur
PostPosted: Thu Nov 03, 2011 12:41 pm Up
Lee, maybe I can buy the pretensioners, ECU and base steering wheel from a crashed. But if the values are cheap like you said, it's pointless, true.
My car's a 2008 multiplexed. I think the version don't have a similar in UK. Here name version name's "Sensation".
PostPosted: Thu Nov 03, 2011 12:44 pm Up
Ahh slightly different on yours then as the airbags are dual stage depending on the severity of the impact.
When the car is crashed you need to remove the crash data from the ECU which is about £60-80, whereas you can buy a uncrashed one for about £20. Same goes with the pretensioners.
Steering wheel needs to come from a 2002 or newer as they use a clip on airbag rather than a screw on one.
muzkur
PostPosted: Thu Nov 03, 2011 12:46 pm Up
The steering wheel is really another one or just the front dash and the airbag itself?
Maybe I can use my steering wheel and just put the airbag inside. Is that possible?
