Online Now [1073]:
Visitors: 1072
Today: 162134
Total: 148921867
Forums › The Car › 206 Problems › fix door hinge
fix door hinge
omricn
PostPosted: Mon Oct 10, 2011 8:02 am Up
hi,
the problem is that the driver's door doesn't have that 2 phase opening, now I know the thingy that does that is a small screw right at the top of the edge of the inside part of the door, but it seems the screw is just sitting there wobbling and doesn't look like it can be screwed anywhere.. any solutions?
Ali_H
PostPosted: Mon Oct 10, 2011 8:25 am Up
You mean the check strap?
kurtis wrote:
omricn
PostPosted: Mon Oct 10, 2011 8:26 am Up
Yeh Confused sorry didn't know that's what it's called..
iainlovatt
PostPosted: Mon Oct 10, 2011 8:33 am Up
4 bolts to undo put a new one on, job done!
(My Garage)
iainlovatt
PostPosted: Mon Oct 10, 2011 8:35 am Up
check strap!
(My Garage)
Ali_H
PostPosted: Mon Oct 10, 2011 8:42 am Up
I need to do the other halfs car when I can be arsed Laughing
Thought they were cheaper than that though, good thing i'm not paying.
kurtis wrote:
iainlovatt
PostPosted: Mon Oct 10, 2011 8:48 am Up
They are expensive arnt they!
(My Garage)
omricn
PostPosted: Mon Oct 10, 2011 9:06 am Up
Holy moly! that's one expensive thingy... I'll see if it can be sorted with the one currently installed and if not I'll pass on it for now.. not that much of a hassle - door is opening all the way and not having that 2 phases opening, I can live with that..
PostPosted: Mon Oct 10, 2011 9:15 am Up
They are only 9181C8 (Right) £26.62 and 9181E1 (Left) £28.74 from the dealers.
Don't know why the difference between right and left though
PostPosted: Mon Oct 10, 2011 9:39 am Up
That is wrong!
There is one part number only- 9181 C8 - check strap is reversible
The other is for a a different type of door opening
PostPosted: Mon Oct 10, 2011 11:26 am Up
That is wrong!
Ah cheers Lee, was wondering what the difference was with it being "post office"
On service box where it says "2" in the column between the part number and item description, does that mean they are supplied as a pair?
Just wondering because the hinge pin has "4" in the column
PostPosted: Mon Oct 10, 2011 11:31 am Up
Means there are 2 on the car
PostPosted: Mon Oct 10, 2011 11:40 am Up
I suppose that makes sense. The French aren't daft then, plus they play rugby better than us, the b******s.
