Latest: morgan20
Overall: 17135
Online Now [1028]:
Visitors: 1027
Today: 79282
Total: 110631239
Forums › The Car › 206 Problems › clock not dimming when lights on
omricn
PostPosted: Mon Oct 10, 2011 12:51 pm Up
So I got in my car this evening and turned on my lights and started driving, a minute later I noticed something was bugging my eyes and found out the Main clock does not dim when turning the lights on.. thoughts?
PostPosted: Mon Oct 10, 2011 1:05 pm Up
Well you can try another clock to see if it will be dimming or not,so if it don't dim,then you have to check for something else,if you could come to Hebron,I can check it for you Smile
PostPosted: Mon Oct 10, 2011 1:07 pm Up
Does the headunit have a display? If so, does that dim?
mtempsch
PostPosted: Mon Oct 10, 2011 1:22 pm Up
Check for broken/disconnected wire in the connector. IIRC, if the wire that signals 'lights on' is broken/interrupted the clock /display remains on bright.
Silvermetallic 2004 206 RC
omricn
PostPosted: Mon Oct 10, 2011 1:54 pm Up
No display mate, only a clock, its a 2001 xsi..
omricn
PostPosted: Mon Oct 10, 2011 1:55 pm Up
Well Timon that'll be a bit dangerous for me.. wish I could though! Thanks for the invite Smile
omricn
PostPosted: Mon Oct 10, 2011 1:57 pm Up
Good advise mate, will check, thanks!
pug-206-boy
PostPosted: Mon Oct 10, 2011 2:16 pm Up
There are 2 buttons coming out from where the speedo is, press and hold I think the right one, should get brighter or darker, press again for vice versa......I'm helping! Very Happy
omricn
PostPosted: Mon Oct 10, 2011 3:14 pm Up
Only one button on my speedo, for trip setting, tried and and didnt do anything but thanks for trying!! Very Happy
Asnyways I kinda' like the clock as it is now, brighter, so I can read it when driving at day time with my lights on Smile
but i'll still check for the wiring to see if something came loos.
colganraz
PostPosted: Mon Oct 10, 2011 3:26 pm Up
you sure there one ? i have two. one one the right which changes mileage display and resets how far you have drove. and one on the left that you click and that adjusts all the lights on the clock and centre display
Former 206 XSi owner - Now 207 GT
www.206info.co.uk/Foru...56475.html
PostPosted: Mon Oct 10, 2011 3:33 pm Up
If the OP only has 1 button on there instrument cluster then they have a non plexed car & will have a dash dimmer wheel next to the headlamp leveler Wink
omricn
PostPosted: Mon Oct 10, 2011 4:00 pm Up
Exactly my case, mine is preplexed
PostPosted: Tue Oct 11, 2011 1:39 am Up
Check the dash dimmer wheel is working correctly, when they fail its normally fully on or fully off, its just a variable resistor on non plexed 206's.
omricn
PostPosted: Tue Oct 11, 2011 4:26 am Up
Thanks mate, dimmer works perfectly
PostPosted: Tue Oct 11, 2011 4:33 am Up
I'd try cleaning the connector plug on the display.
