Online Now [191]:
Visitors: 191
Today: 44017
Total: 138723027
Forums › The Car › 206 Problems › Passenger side jet washer not working
acotton21
PostPosted: Thu Oct 13, 2011 8:02 am Up
Drivers side works ok just the passenger side, ive tried poking it and still nothin.
PostPosted: Thu Oct 13, 2011 8:07 am Up
Checked the pipes aren't blocked or popped off on the underside of the bonnet?
acotton21
PostPosted: Thu Oct 13, 2011 8:23 am Up
yea all seems fine there
paul_c
PostPosted: Thu Oct 13, 2011 8:32 am Up
It will be the nozzle, needs replacing. Poking it can clear a small blockage, but if its anything bigger, just pushes the crap right into it.
acotton21
PostPosted: Thu Oct 13, 2011 8:46 am Up
so i need new washer jets??
acotton21
PostPosted: Thu Oct 13, 2011 8:49 am Up
could it still pass MOT with 1 working?
PostPosted: Thu Oct 13, 2011 8:51 am Up
Have you tried taking it off and blowing through it to make sure it's clear?
ExoVyper
PostPosted: Thu Oct 13, 2011 10:20 am Up
you'll fail an mot with only one working
acotton21
PostPosted: Thu Oct 13, 2011 10:23 am Up
Its just passed Smile
ExoVyper
PostPosted: Thu Oct 13, 2011 10:24 am Up
it shouldn't have as it'll usually get put down with inadequate cover or something :L
paul_c
PostPosted: Thu Oct 13, 2011 12:50 pm Up
That should be a concern. If they've missed something as simple to check as a washer jet, what other safety items have they missed, which are more difficult for an owner to check themselves? Or are you just happy it passed and that will do?
acotton21
PostPosted: Thu Oct 13, 2011 12:59 pm Up
i did say ive had problems with it as it went in
Antknee
PostPosted: Thu Oct 13, 2011 1:14 pm Up
That isn't right surely lol, mine failed because of that
acotton21
PostPosted: Thu Oct 13, 2011 1:28 pm Up
think because 1 worked and the other worked a little bit
Antknee
PostPosted: Thu Oct 13, 2011 1:31 pm Up
yeahh mine did but still went down as insufficient fluid on the windscreen or something lol
