Latest: Beduff1977
Overall: 17134
Online Now [283]:
Visitors: 282
Today: 114945
Total: 107104854
Forums › The Car › 206 Problems › Passenger side jet washer not working
Go to page Previous  1, 2
Andy180+
PostPosted: Thu Oct 13, 2011 1:33 pm Up
acotton21 wrote:
could it still pass MOT with 1 working?
The car will pass with just one working as long as there is sufficiant fluid on the screen to clear a path of vision for the driver . coming from a HONEST tester
(not to say all testers are not honest)
PostPosted: Thu Oct 13, 2011 1:34 pm Up
MOT's don't mean jack s**t as soon as you've pulled out of the garage. VOSA could stop you and fail your car.
An MOT is just a money making scheme.
Andy180+
PostPosted: Thu Oct 13, 2011 1:36 pm Up
now now Lee you know better than that, a mot means the car has passed a minimum standard of raod safty at the time it was tested
Exactly, means jack s**t Laughing
And if you get a flash file of your ECU, email it me, and I'll ask to see if I can get cruise control sorted.
Andy180+
PostPosted: Thu Oct 13, 2011 1:39 pm Up
how about we sort out to meet. dont complicate s**t with big words, i am only a mechanic ffs lol
PostPosted: Thu Oct 13, 2011 1:49 pm Up
I only have a galletto, think you need a MPPS or better to flash the IAW 6LPA.01
Will need to check.
138Andy
PostPosted: Thu Oct 13, 2011 2:26 pm Up
my car passed with the window washers not working , just put it as an advisory
kit325
PostPosted: Fri Oct 14, 2011 2:49 am Up
Do u use just tap water for refilling, normally limescale will built up and causing problems to the nozzles. Try use something like a sewing needle the clear any blockage in the nozzles. It works for me when same situation happen to me.
kit
PostPosted: Fri Oct 14, 2011 3:23 am Up
+1
Page 2 of 2
