Latest: SA01
Overall: 17138
Online Now [1641]:
Visitors: 1640
Today: 40185
Total: 111354579
Forums › The Car › 206 Problems › door unlocking no not bouncing locks
broadblaster
PostPosted: Mon Oct 17, 2011 12:07 pm Up
right my daughter has been useing my 04 180 and she has somehow done somthing to the locks
it will not unlock on the fob but you can undo the doors with the key in the barrel, then it will relock on the fob if you wish but not unlock.
the boot will not open and the doors will not open from inside.
so i think she had deadlocked it or somthing.
how do it get them to unlock on the fob again please.
on a back road playing
glenpring
PostPosted: Mon Oct 17, 2011 1:31 pm Up
I don't know if it is but try re syncing your key to the car put key in ignition and turn 1 click then push the lock button in your fob for 10 seconds then take the key out of the ignition and try locking and unlocking. If I'm wrong I'm sure someone will let you know.
broadblaster
PostPosted: Mon Oct 17, 2011 1:43 pm Up
ok mate i will give that a go thanks
broadblaster
PostPosted: Mon Oct 17, 2011 1:49 pm Up
right well that don't work lol lol
have noticed that the led by the hazzard light switch is flashing really fast non stop when i try to use the button to open the locks. the interior light comes on as it does normaly
glenpring
PostPosted: Mon Oct 17, 2011 1:55 pm Up
Lee or mrbsi might be the people you need then sorry I couldn't be any help
PostPosted: Mon Oct 17, 2011 1:59 pm Up
Alarm system has been triggered.
broadblaster
PostPosted: Mon Oct 17, 2011 2:04 pm Up
ah right thats probrly me playing about tbh
have also noticed that only the one door unlocks with the key not all of them as i would have thought it should.
trying to work my way throught the search but not found the same problem yet.
PostPosted: Mon Oct 17, 2011 2:09 pm Up
Sounds like a defective door solenoid to me.
Turn the ignition ON / start the engine if the deadlocks are stuck on, the built in safety logic should then disarm them.
broadblaster
PostPosted: Mon Oct 17, 2011 2:17 pm Up
i have started and driven the car for over 1/2 hr to get home with no problems but it still wont unlock with the fob so am i looking at a faulty solenoid then ??.
when pressing the button you can here the boot click but still will not open the same as the doors.
have checked the fuse all ok i have also done a bsi reset as per instuctions on this site.
just seem strange that they will (doors) lock ok with the fob.
PostPosted: Mon Oct 17, 2011 2:20 pm Up
Open the boot manually from inside, fold the rear seat down & then pull the tailgate interior trim panel off.
No deadlock on the boot, simple 2 wire lock motor.
broadblaster
PostPosted: Mon Oct 17, 2011 2:23 pm Up
sorry to sound a dumb ass but once i have got to the boot lock i presume i can unbolt it to open the boot then what do i check ???
PostPosted: Mon Oct 17, 2011 2:25 pm Up
No need to unbolt anything, slide the lock motor rod accross / yank on the latch rod to pop the tailgate open.
Trim panel is clipped on with metal clips, sounds like they are breaking, yank hard at the bulge in the top & they will pop of.
broadblaster
PostPosted: Mon Oct 17, 2011 2:37 pm Up
ok thanks for that. do you think its the boot one at fault then ???? i supose once i get the boot open i can try to see if it moves when the button is pressed.
PostPosted: Tue Oct 18, 2011 8:07 am Up
Possible, soon find out Laughing
broadblaster
PostPosted: Tue Oct 18, 2011 11:37 am Up
well not so soon mate its gonna have to wait untill i get a day off.
