Latest: lio94
Overall: 17181
Online Now [175]:
Visitors: 174
Today: 105128
Total: 141859270
Forums › The Car › 206 Problems › Hesitating to accelerate/juddering
shaunc
PostPosted: Tue Oct 18, 2011 4:14 am Up
So....
Recently my 1.4 LX has started running a bit ruff. The main problem is when I am travelling at 20/30 mph at a steady acceleration and the car will just pull back for some reason. It will only happens for a split second and it only does it every so often, about once every 15/20 minutes.
Also the engine has also gradually started sounding a bit louder and a bit "tractory" when sat still in neutral or first gear with the clutch down.
It has has a full service about 2 month ago (with bosch super 4's) and it was running great just after theservice, this problem has only started days ago.
Any ideas??
(Sorry if this has already been posted before, I did try searching first Rolling Eyes )
>>206 project soon to be started!
mattievrs
PostPosted: Tue Oct 18, 2011 6:13 am Up
get the throttle body cleaned out and clean up the map sensor.
NO LONGER ACTIVE ON THE FORUM
shaunc
PostPosted: Tue Oct 18, 2011 12:45 pm Up
Thanks for the reply....
I cleaned and polished the throttle body and inlet pipes when I
t was serviced it so I don't think it will be that. I've had a look at the MAP sensor and it didn't seem to bad but I cleaned it up anyway, it didn't have any effect though. But one thing I did notice is that the MAP sensor looks different from ones I've seen on ebay etc, because it doesn't have the pointed shape part on the end.
Is this normal?
Any further ideas?? :/
shaunc
PostPosted: Wed Oct 19, 2011 8:57 am Up
Could it be the coilpack? as the plugs i removed were NGK's, could this have done some damage at all?
leigh_boy
PostPosted: Fri Oct 21, 2011 3:48 am Up
i had a probably like this and it was the super 4 plugs being faulty put the proper pug plugs in and problem solved.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
Gaz360
PostPosted: Fri Oct 21, 2011 4:36 am Up
Ive had problems with map sensors before. would be worth getting one that you know is definatly working cuz they are easy to swap an check. bloody sensors!
LeeMaddern
PostPosted: Fri Oct 21, 2011 4:49 am Up
could also be the EGR valve
More photos on FaceBook - www.facebook.com/lmaddern1
Pug-Lee-2011
PostPosted: Fri Oct 21, 2011 5:02 am Up
Trade Rating: -1
yea egr valve went on mine !
