Latest: cogeim7
Overall: 17185
Online Now [712]:
Visitors: 711
Today: 258323
Total: 147524412
Forums › The Car › 206 Problems › Have to wait before starting
haggis120
PostPosted: Tue Oct 18, 2011 6:37 pm Up
Hi, I have a problem that has just started. I have to turn ignition on and wait till dash lights go out air bag etc.. before I can start the engine.
If I try to start it before it will not start and then I have to leave it for five or ten minutes as it will not start even if I wait till the lights go out.
Any ideas would be great. thanks
A 2002 206 1.4 hdi
haggis120 206 1.4 Hdi, 2002
NICKST
PostPosted: Wed Oct 19, 2011 12:24 am Up
Worn glow plugs when were they last changed?
haggis120
PostPosted: Wed Oct 19, 2011 12:31 am Up
I dont know when I have only had the car 4 months. Will check this out. Cheers
Ash
PostPosted: Wed Oct 19, 2011 12:44 am Up
It's a 9 year old derv.. Let it warm it's plugs. If it struggles to start, let it warm them again.
haggis120
PostPosted: Wed Oct 19, 2011 12:51 am Up
I can understand that but why do I have to leave it for 5 to 10 mins until I try again?
20619d
PostPosted: Wed Oct 19, 2011 1:36 am Up
try changing glow plug rely to as mine had same probably and did that and put new glow plugs in and now starts fine
haggis120
PostPosted: Wed Oct 19, 2011 1:39 am Up
Cheers! where is the glow plug relay at?
20619d
PostPosted: Wed Oct 19, 2011 1:43 am Up
mine was behind my batt box. it was b olted to side of it. mine a 1.9d so might be in diff place.
PostPosted: Wed Oct 19, 2011 2:06 am Up
Doubt its glow plugs, you wouldnt be using them at this temperature. Can you hear the engine priming ok?
MRyan89
PostPosted: Wed Oct 19, 2011 2:36 am Up
I normally just wait until the stop light and abs lights etc turn off anyway, its better to let it prime itself!
DanPug206
PostPosted: Wed Oct 19, 2011 4:42 am Up
I always let my lights go out before attempting a start up, takes 5 seconds then your off.
Saphire Blue 206 (Gti Replica) SOLD
08 Seat Ibiza Sport
PostPosted: Wed Oct 19, 2011 5:19 am Up
Check the battery.
paul_c
PostPosted: Wed Oct 19, 2011 5:26 am Up
A 2002 206 1.4 hdi
When you say "not start" does the engine turn over at normal starting speed but not fire; or does it turn over slowly or not at all? Or some other issue?
Antknee
PostPosted: Wed Oct 19, 2011 5:40 am Up
What He Said
haggis120
PostPosted: Wed Oct 19, 2011 10:56 am Up
Paul-c, the engine turns over just fine.
Steve206, what does the engine priming sound like?
This has just started it didnt matter weather I left the lights to go out or not.
