Latest: kemppu
Overall: 17142
Online Now [122]:
Visitors: 121
Members: 1
Today: 13033
Total: 114052324
Forums › The Car › 206 Talk › Radiator Help?
Radiator Help?
deebee
PostPosted: Wed Oct 19, 2011 11:31 am Up
Hiya guys,
Ive brought my car and in the last month the drive shafts gone, and now the rad on its way out because it steaming! so, can someone advise if changing the rad myself is good idea if so point me in direction of how to i have had a look buttt, cant find Sad !!!!! Sad
cheers x
Breaking 2.0 hdi with ps and gti bits
DanPug206
PostPosted: Wed Oct 19, 2011 3:26 pm Up
I changed mine mate by myself think there's bolts holding it at the top then you need pliers to undo the clips connecting the pipes, then reverse the process, just make sure you bleed the new rad as you don't want it getting air locked and overheating again.
If I'm wrong I'm sure someone will correct me.
Saphire Blue 206 (Gti Replica) SOLD
08 Seat Ibiza Sport
deebee
PostPosted: Thu Oct 20, 2011 1:14 pm Up
thats only problem im struggling with, bleeding and refilling ect.
paul_c
PostPosted: Thu Oct 20, 2011 1:39 pm Up
Cut the bottom off a lemonade bottle, put it upside down into the coolant tank and use duct tape to seal it, then fill gradually with the engine running and the heater on full. You'll be able to observe the air bubbles work their way out of the system.
