Online Now [320]:
Visitors: 318
Members: 1
Today: 32876
Total: 145338675
Forums › The Car › 206 Problems › Car not starting without having to press accelerator
Norvvv
PostPosted: Wed Apr 27, 2011 1:04 am Up
Better bang some red-ex in then! :L
2001 1.4lx
PrePlexed 5 door.
DJRogers88
PostPosted: Sun Oct 23, 2011 10:40 am Up
Hi,
I know this is reviving an old topic now but this has been left until now where it is getting worse. The problem only seems to be when it has been used for a while and a mate has read the ECU which is showing no faults. However it is showing the throttle pedal at around 12% when the engine isn't even turned on and only goes up to 80% when pressed all the way down. My mate is saying it is probably the throttle pedal at fault as the ECU is thinking you have your foot on the pedal so isn't starting the engine. Does this sound like it could be right? Also, we have found some new parts on ebay with the part number 1601 - V8 but we don't know if this is the right part (around £25) we have had a look on the pedal itself and it just looks like its 3 bolts and a cable attachment but we can't see any numbers that corresponds to that on ebay... If anyone can help with getting a part number I could probably get one ordered and get someone to fit it, just need to verify the part number. Car is a 207, 57 plate, 1.4 urban (petrol)
Thanks..
PostPosted: Sun Oct 23, 2011 10:49 am Up
Should fit the 207, pm me the VIN number & ill have a look for you.
DJRogers88
PostPosted: Sun Oct 23, 2011 11:07 am Up
Thanks - PM'd
PostPosted: Sun Oct 23, 2011 12:01 pm Up
Part number 1601 V8 is the correct pedal for your 207.
PostPosted: Sun Oct 23, 2011 10:00 pm Up
DJRogers88 wrote:
Hi,
Thanks..
I think you might find this is actually normal..
I looked into this on our '07 206 with electric pedal and had the same exact figures.
We get the ocassional flubber at start-up if it hasn't been used for a couple of days. Like the revs (and needle) drops to almost zero and then picks-up and runs normaly after that. All this without pressing the pedal.
Let me know how you get on.
I also have an electric pedal for a UK (RHD) 207 if you want for the price of postage.
Cheers.
DJRogers88
PostPosted: Mon Oct 24, 2011 2:14 am Up
Hi,
Hmm strange, this is when it's just been used.. Anyone else confirm that these readings should be like that? Thanks for the pedal offer but have already got one on order now.
PostPosted: Mon Oct 24, 2011 6:24 am Up
DJRogers88 wrote:
Hi,
Yeh I asked the same back then, only macj answered and seemed to think they were normal.
DJRogers88 wrote:
Hi,
K
DJRogers88
PostPosted: Wed Oct 26, 2011 3:03 pm Up
Ok the part has now arrived (though the sticker on the part says xx.xx.06 and the one currently on says xx.xx.07 - does this make a difference?) and I was going to get someone to fit, however looking at it, it looks pretty simple to fit? 3 bolts to unscrew and one electric plug to plug in? Anyone know if its more difficult than it looks?
Thanks again.
PostPosted: Wed Oct 26, 2011 11:03 pm Up
Most likely find that will be the date the part was made.
DJRogers88
PostPosted: Thu Oct 27, 2011 6:36 am Up
Yeah thanks for that. You know anything about fitting it?
PostPosted: Thu Oct 27, 2011 9:42 am Up
I would reset the BSi once fitted.
Infact you might as well dis-connect the battery before carrying-out the work in that case.
Make sure you shut-down/boot-up properly though..
And let us know esp. what readings you get afterward.
DJRogers88
PostPosted: Thu Oct 27, 2011 10:47 am Up
Great, thanks for advice.
PostPosted: Tue Nov 01, 2011 7:16 pm Up
Fitted?
Any update?
DJRogers88
PostPosted: Wed Nov 02, 2011 1:59 am Up
Hi, not been fitted yet - was supposed to be today but have had to work away. Be this time next week probably.
Page 2 of 3
