Online Now [149]:
Visitors: 149
Today: 22021
Total: 138812477
Forums › The Car › 206 Problems › Intermittent Revving 206 1.1 *PLEASE HELP*
galaxly
PostPosted: Sun Aug 28, 2011 10:43 am Up
Hi I was wondering if you can advise me on a solution to solve a reving issue on a peugeot 206 1.1 It starts fine but after a few minutes it revs quite high on its own for about a minute or so than gets back to normal. It does this each time i start the car and drive.
Also lately ive noticed that the car sometimes struggles to start. Could this be related? I've recently put in a new battery but im still having this issue.
Shiz
MrrNoName
PostPosted: Sun Aug 28, 2011 10:53 am Up
They could be related, check/clean/replace the idle control valve, this would be my number one suspect (although revving problems can occur without this being at fault). The ICV is what regulates the engine speed at idle. Also look at the throttle position sensor.
Is the EML (engine management light) on?
galaxly
PostPosted: Sun Aug 28, 2011 11:06 am Up
The EML isn't on. I was just reading another post and it seems they got this exact problem fixed by replacing the ETS. But I have no idea what an ETS is or stands so. Have you any idea?
Shiz
Lecktorious
PostPosted: Sun Aug 28, 2011 11:16 am Up
Trade Rating: +59
Was going to give you a starting point - use the search function.
'98 Nile Blue 306 GTi 6
macj
PostPosted: Sun Aug 28, 2011 11:17 am Up
Engine temp sensor... usually on your thermostat housing but I dont know the 1.1
galaxly
PostPosted: Thu Sep 01, 2011 12:43 pm Up
Problem sorted.. thanks guys
Shiz
MrrNoName
PostPosted: Thu Sep 01, 2011 5:17 pm Up
And the solution was?
Its worth saying because it might help others.....
panzer360gti
PostPosted: Fri Sep 02, 2011 8:29 am Up
he bought a fiat.
Peugeot 206 GTI 137 2.0
galaxly
PostPosted: Fri Sep 30, 2011 3:38 am Up
Solution was changing the green temperature sensor.. £15 quid from peugeot.. I still got the car but now that its fixed i'll be selling it. My car also used to give problems starting at times and this little sensor sorted that out too. I hope this helps anyone out there with who comes about similar issues
Shiz
fluffy
PostPosted: Mon Oct 24, 2011 3:08 am Up
I had a similar problem where the car lost all Exceleration and car would some times over rev on its own.
Took to a a garage and they said the temperature reading was really high so had temperature sensor changed and that fixed it.
The problem I have now is that the Temperature gauge needle seems to go high, about One digit from near the red. This is mainly when driving on Motor ways at fast speeds.
It used to stay on 90"" about half way on the gauge, but now the needle seems to go up and down all the time.
Could this be Faulty Thermostat, Faulty Temp sensor (1 year old) or maybe worse ??
Deckchair5
PostPosted: Mon Oct 24, 2011 8:42 am Up
It might simply be that the coolant hasn't been bled properly after fitting the ETS. Air in the system will mean sudden hot spots and cooling
