![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › GTI6 Conversion Help |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Wed Oct 26, 2011 9:52 am |
Trade Rating: +46
yer all there..
| | ![](images/spacer.gif) |
Posted: Wed Oct 26, 2011 11:42 am |
LeeThr wrote: |
If your gonna drop the 180 engine in, easiest thing is to rip the entire preplex wiring loom out of yours and get the 180's multiplex loom from shell's along with the engine, ecu bsi, transponder chip & ariel etc |
A good idea but no way would I try that without the donor car sat alongside.
What about stuff like the ABS unit which is different, the ABS sensors too.
Posted: Wed Oct 26, 2011 12:01 pm |
Trade Rating: +46
all there to take..
Posted: Wed Oct 26, 2011 12:04 pm |
Is it going to be a road or track car?
| ![](themes/base/images/forums/otr.gif) |
