Latest: Kifi69
Overall: 17183
Online Now [540]:
Visitors: 540
Today: 74724
Total: 144221758
Forums › The Car › 206 Talk › Whats this mean?
Whats this mean?
Forum Index › 206 Talk
mjsroofing
PostPosted: Thu Oct 27, 2011 1:43 pm Up
that means oil level is fine.
the lines are the lines on your dip stick, if the last line line to the right goes then your 1 fifth of a litre of oil short from being full of oil. look in your hand book.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
PostPosted: Thu Oct 27, 2011 3:20 pm Up
It doesnt, the boxes are the amount of oil, the oil level in that picture is nearly on the min!
Dave82517
PostPosted: Thu Oct 27, 2011 6:06 pm Up
I must have the older bsi software, because my oil level sensor is about as much use as a waterproof teabag! Id get a more acurate reading if i asked a psychic to read some tea leaves and tell me the level!! : Confused
That is all.
mjsroofing
PostPosted: Fri Oct 28, 2011 2:02 pm Up
no the lines are the level, i'm sure they are, or is mine at fault too
Mark
PostPosted: Fri Oct 28, 2011 2:06 pm Up
Don't forget you need the BSI update, so your oil sensor will be s**te Wink
Use the dipstick anyway
mjsroofing
PostPosted: Fri Oct 28, 2011 2:11 pm Up
always use the dip stick mate, only a dip stick wouldnt use a dip stick. them sensors play up all the time., i change the oil evry 5k on my cars so it dont get much chance of running low any way.
Mark
Dutch-HDi
PostPosted: Fri Oct 28, 2011 2:15 pm Up
Sorry to go off topic, just a quick question about the bsi update, does puegeot automatically update the bsi software if needed when taken in for service or is it something thats needs requesting when booking the car in
Never had any problems with mine unless i park at the top of the drive thats on an incline then it reads a little low but i always check the stick anyways
206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955)
PostPosted: Fri Oct 28, 2011 2:25 pm Up
Not unless it's under warranty or a recall
PostPosted: Sat Oct 29, 2011 8:27 am Up
The lines are NOT the level, RTFM, the box shapes are the amount of oil on the gauge.
PostPosted: Sat Oct 29, 2011 8:29 am Up
mjsroofing
PostPosted: Sat Oct 29, 2011 9:17 am Up
so i guess that the gauge on my car doesn't work then.
Mark
mjsroofing
PostPosted: Sat Oct 29, 2011 2:59 pm Up
i'm wrong again mine does work i checked earlier, it says that i'm full of oil.
Mark
PostPosted: Sat Oct 29, 2011 9:12 pm Up
As said above, the level indicator in the photo is showing a low level.
mjsroofing
PostPosted: Sun Oct 30, 2011 3:27 pm Up
i think we have worked that one out now.
Mark
PostPosted: Tue Nov 01, 2011 1:51 am Up
As you were the only one to offer wrong advice on the subject, you mean you've worked it out now Rolling Eyes
Page 2 of 3
