Posted: Thu Oct 27, 2011 1:43 pm |
that means oil level is fine.
the lines are the lines on your dip stick, if the last line line to the right goes then your 1 fifth of a litre of oil short from being full of oil. look in your hand book.
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Thu Oct 27, 2011 3:20 pm |
mjsroofing wrote: |
the lines are the lines on your dip stick, if the last line line to the right goes then your 1 fifth of a litre of oil short from being full of oil. look in your hand book. |
It doesnt, the boxes are the amount of oil, the oil level in that picture is nearly on the min!
Posted: Thu Oct 27, 2011 6:06 pm |
I must have the older bsi software, because my oil level sensor is about as much use as a waterproof teabag! Id get a more acurate reading if i asked a psychic to read some tea leaves and tell me the level!! :
Posted: Fri Oct 28, 2011 2:02 pm |
no the lines are the level, i'm sure they are, or is mine at fault too
| Mark
Posted: Fri Oct 28, 2011 2:06 pm |
mjsroofing wrote: |
no the lines are the level, i'm sure they are, or is mine at fault too |
Don't forget you need the BSI update, so your oil sensor will be s**te
Use the dipstick anyway
Posted: Fri Oct 28, 2011 2:11 pm |
always use the dip stick mate, only a dip stick wouldnt use a dip stick. them sensors play up all the time., i change the oil evry 5k on my cars so it dont get much chance of running low any way.
| Mark
Posted: Fri Oct 28, 2011 2:15 pm |
Sorry to go off topic, just a quick question about the bsi update, does puegeot automatically update the bsi software if needed when taken in for service or is it something thats needs requesting when booking the car in
Never had any problems with mine unless i park at the top of the drive thats on an incline then it reads a little low but i always check the stick anyways
| 206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955) | |
Posted: Fri Oct 28, 2011 2:25 pm |
Not unless it's under warranty or a recall
Posted: Sat Oct 29, 2011 8:27 am |
mjsroofing wrote: |
The lines are NOT the level, RTFM, the box shapes are the amount of oil on the gauge.
Posted: Sat Oct 29, 2011 8:29 am |
mjsroofing wrote: |
Posted: Sat Oct 29, 2011 9:17 am |
so i guess that the gauge on my car doesn't work then.
| Mark
Posted: Sat Oct 29, 2011 2:59 pm |
i'm wrong again mine does work i checked earlier, it says that i'm full of oil.
| Mark
Posted: Sat Oct 29, 2011 9:12 pm |
mjsroofing wrote: |
i'm wrong again mine does work i checked earlier, it says that i'm full of oil. |
As said above, the level indicator in the photo is showing a low level.
Posted: Sun Oct 30, 2011 3:27 pm |
E5GDM wrote: |
mjsroofing wrote: |
As said above, the level indicator in the photo is showing a low level. |
i think we have worked that one out now.
| Mark
Posted: Tue Nov 01, 2011 1:51 am |
mjsroofing wrote: |
E5GDM wrote: |
mjsroofing wrote: |
i think we have worked that one out now. |
As you were the only one to offer wrong advice on the subject, you mean you've worked it out now
