Online Now [1075]:
Visitors: 1074
Today: 217010
Total: 149283660
Forums › The Car › 206 Problems › Headlights goes on when braking
kurosagi01
PostPosted: Wed Nov 02, 2011 5:05 pm Up
So my car decides to have another fault,whenever i press the brakes the front lights goes on aswell which is rather worrying people may assume i am giving way to to them out in day light.
And i got warning light on my dash once again,i assume it be electric fault.
I am honestly giving up with this car with the amount of diagnostics its been and repairs.
cartoonhead
PostPosted: Wed Nov 02, 2011 5:12 pm Up
have you changed any of your rear bulbs recently ?
kurosagi01
PostPosted: Thu Nov 03, 2011 2:47 am Up
I've only installed new rear lights,only installed my old bulbs into the lexus lights.
craigdmjv
PostPosted: Thu Nov 03, 2011 2:50 am Up
research the comms2000 unit faults and make sure you have all the correct bulb types either that or flow the earth and clean the connections
PostPosted: Thu Nov 03, 2011 3:17 am Up
What rear light have you got? Sounds like you have a single filament bulb in a double slot to me.
cartoonhead
PostPosted: Thu Nov 03, 2011 3:56 am Up
What He Said
LiamGTi180
PostPosted: Thu Nov 03, 2011 5:46 am Up
yeah that happened to me once. felt like a right plonker
kurosagi01
PostPosted: Thu Nov 03, 2011 12:26 pm Up
I've got black rear lights Ben lol,you seen my car.
As for bulbs the brake light bulbs are from my original rear lights which came from phase 2 to phase 1/tinted to lexus now.
PostPosted: Thu Nov 03, 2011 12:32 pm Up
Put the bulbs in upside down?
kurosagi01
PostPosted: Thu Nov 03, 2011 1:13 pm Up
Does that actually makes a different?? It would help if the seller i bought gave me a diagram or whatever to which bulbs go into what. The bulbs on the reverse and brake are same aren't they? They are exactly identical.
PostPosted: Thu Nov 03, 2011 1:17 pm Up
Yeah I can do if they are double filament.
PostPosted: Thu Nov 03, 2011 1:29 pm Up
The bulb on reverse and indicator are the same.
Have a look at the brake bulb and see if it has one blob of solder on the bottom. More than likely you need the bulb with 2 blobs on (said simply so it's understood)
