Latest: cogeim7
Overall: 17185
Online Now [419]:
Visitors: 418
Today: 187493
Total: 147296604
Forums › The Car › 206 Talk › LED Numberplate Bulbs
Forum Index › 206 Talk
PostPosted: Thu Nov 03, 2011 4:55 am Up
Hereford wrote:
Cheers mate,
I've just bought the ones that Macca1411's got on his mate. They look pretty good to me, plus cheap!
Thats where your wrong had the same ones in mine and they failed with a 2 week period they loose the solder on the pins and just fall apart
PostPosted: Thu Nov 03, 2011 5:32 am Up
Mikey2uk wrote:
Hereford wrote:
Cheers mate,
I've had mine in 6 months now and still going strong.
You can't really say that buying the cheaper ones is a waste of money. I could buy the cheap ones from Hong Kong for 99p, inflate the price and sell them from the UK. It's easy enough to do, and some sellers are doing that.
The only way you can guarantee quality is to buy branded, but even then it's not 100%, the chances are they are made in the same factory as the cheap stuff.
gazza82
PostPosted: Thu Nov 03, 2011 5:44 am Up
I tried some for the front of the CC that are covered in a plastic dome ... like these ...
http://www.ebay.co.uk/itm/2-x-T10-501-Wedge-White-LED-Bulbs-Sidelight-Lamp-/180749100972?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a157c67ac
not very bright at all! Don't think they came off ebay either!
myke
PostPosted: Thu Nov 03, 2011 9:14 am Up
Mikey2uk wrote:
Hereford wrote:
Cheers mate,
I still think the ones you made with the huge panel of SMDs made the LED's look like they were meant to be there, which was cool
PostPosted: Thu Nov 03, 2011 9:21 am Up
You mean these
I can make them still if anyone is interested
dumdum0910
PostPosted: Thu Nov 03, 2011 9:26 am Up
you can buy them led number plate lights off ebay ..
PostPosted: Thu Nov 03, 2011 9:27 am Up
Yeah they are about £40 to buy I can do them for £20 posted
Ali_H
PostPosted: Thu Nov 03, 2011 9:31 am Up
What's the point of LED numberplate bulbs anyway?
kurtis wrote:
PostPosted: Thu Nov 03, 2011 9:45 am Up
Those ones are crap, you need the SMD LED.
This is the 5 SMD
Mikey2uk wrote:
You mean these
I like those Mikey, no chance of someone not seeing your plate with those lit up
gazza82
PostPosted: Thu Nov 03, 2011 9:48 am Up
Last longer!! Wink
Ali_H
PostPosted: Thu Nov 03, 2011 9:55 am Up
Cool beans, i've only ever needed to replace one once so i'll give it a miss lol.
kurtis wrote:
Ash
PostPosted: Thu Nov 03, 2011 10:41 am Up
So the cops can read your plate easier Smile
Debz
PostPosted: Fri Nov 04, 2011 1:17 am Up
ive got the LED number plate bulbs, how long do they last roughly as they would always blow in my last car and only last a few months (it was a ford, no comments please haha) x
My Name is Debora and Im a member of Nerdz-anonomus haha
ARRAN
PostPosted: Fri Nov 04, 2011 10:47 am Up
i bought these ones and there very bright
www.ebay.co.uk/itm/170...1439.l2649
See my project here.
mtempsch
PostPosted: Fri Nov 04, 2011 2:18 pm Up
LED's ran within their 'normal' parameters typically last 50-100.000 hours - i.e. would likely outlive the car.
But I'd believe most of the cheap stuff is likely to run them harder (higher current through them which gives more light but shortens life).
Another problem is that (white) LED's operate at ~~3-3,6V depending on exact design, and the car supplies anywhere from about 11-14,5V. If you run a single LED off the cars supply, the difference in voltage must be handled somehow... Simplest and cheapest is a series resistor that at the approximate wanted current through the LED drops the difference between supply voltage and LED operating voltage across itself. Since the supply voltage is not fixed this is pretty much a 'get it close enough' thing anyway...
Also, in a small package like a wedge bulb, the resistor can't be big, and for the possible size, the heat generated in the resistor (function of voltage across it times current through it) becomes pretty significant and might cause the resistor to burn out or solder joints to fail long before the actual LED element fails.
Silvermetallic 2004 206 RC
Page 2 of 3
