Latest: cogeim7
Overall: 17185
Online Now [880]:
Visitors: 879
Today: 260198
Total: 147738127
Forums › The Car › Solved 206 Problems › Hesitant to Start when cold BUT.. [-SOLVED-]
Forum Index › Solved 206 Problems
PostPosted: Sat Nov 05, 2011 9:49 am Up
Lee wrote:
Fuel pressure 3.5bar + or - 0.5bar
PSA Service Bulletin
Razz
where did you find all these PSA Service Bulletin
PostPosted: Sat Nov 05, 2011 9:51 am Up
My servicebox account Smile
PostPosted: Sat Nov 05, 2011 9:54 am Up
macj wrote:
The fact that it is fine when warm suggests it is a fuelling issue, My thoughts are that it is not adding the extra choke fuel on initial start up. When you say the ETS is ok do you mean you have replaced it or just that there are no fault codes?
I would clean out your throttle body, checking for corrosion or deposits. If the answer to the above question is "no codes" then get a new ETS. I would imagine this is not hard to start from hot?
I have monitored the ETS carefully with diag tool and I'm pretty sure it's OK. That is the first thing I thought too (see first post).
From hot or even after a succesfull start running for a few seconds, it then fires-up straight-away perfectly every time.
Throttle body looks in mint condition, no corrosion and butterfly seems to be opperating smoothly when pushed with finger (2007 car).
It's a puzzle.
Could it be the actuator of the TB is problematic..
PostPosted: Sat Nov 05, 2011 9:59 am Up
'Will check Lee, thanks.
I don't think it's an earth issue tbh though. I'll see about the pressure and double check anyway.
Could the previous owner have mapped it and could this be causing this?
macj
PostPosted: Sat Nov 05, 2011 10:18 am Up
I will pop over and have a look.... Got a mate who lives in Sitia on Crete Laughing
PostPosted: Sat Nov 05, 2011 10:24 am Up
Laughing
You're welcome to anytime.
Lee said he would but hasn't got round to it.
Maybe he is afraid of the current situation over here. Anyway, different topic for that in a few months time..
PostPosted: Sat Nov 05, 2011 11:14 am Up
Update:
Just checked with live data, I only seem to have "FUELSYS:" which says OL with engine off and CL when engine
is running. No pressure reading parameter anywhere.
But leaving the key in the ON position for a while before starting, made no difference whatsoever. Hessitant again.
I should point out that the behaviour of the slight jolt (see link in first post) is still there after all these months. Could this be connected I wonder?
Question: Am I right in thinking the Oxygen sensor (1st, pre-cat) is ignored at start-up until the ellement is warm?
Otherwise, I have here an OK sensor from when I replaced mine a while back, worth giving that a try?
Coolspot
PostPosted: Sat Nov 05, 2011 11:35 am Up
My car does this when cold and runs fine after clearing out the cold air through the system.
I have found that she does not like cold air being rammed up her grills.
We had a oxygen sensor replaced a while ago i can't remember if it was like this then but its always been their as far ass i'm aware but the wife did have major issues with it a few winters ago when it was really cold and wouldn't start for quite a while.
Good luck
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
PostPosted: Sat Nov 05, 2011 11:47 am Up
Have you checked the earth wires?
PostPosted: Sat Nov 05, 2011 11:59 am Up
The ones coming-off the battery onto the chassis, gearbox etc are tight and fine for sure.
Engine temp sensor is also fine by the readings from the diag tool.
Is the O2 sensor ignored at startup?
What is 'FUELSYS:' parameter OL and CL anyone know?
P.S. Lee I think you just broke the site.
PostPosted: Sat Nov 05, 2011 12:05 pm Up
CL = closed loop
OL - open loop.
No the one from the ECU to earth
PostPosted: Sat Nov 05, 2011 12:07 pm Up
Lee wrote:
CL = closed loop
OL - open loop.
What there is a strap there? Apart from the 3 connectors?
Will check ASAP.
PostPosted: Sat Nov 05, 2011 12:18 pm Up
There are about 5 earthing points under the bonnet. Near both front lights, strut (battery side), gearbox, crossmember, maybe a few more.
Take a look at the connector on the ECU and see where the earthing point is.
I'll try and find it
PostPosted: Sat Nov 05, 2011 12:28 pm Up
The ECU earthing points of MC01 and MC11
Clean the contacts
Daeva
PostPosted: Sat Nov 05, 2011 12:40 pm Up
Thank you so much for all your thoughts, guys. Really appreciated.
We'll check tomorrow when the sun is out!
Very Happy
1.4i, 2007, TU3A, 5-door, Moonstone
Page 2 of 3
