Online Now [275]:
Visitors: 274
Today: 67543
Total: 142577964
Forums › The Car › 206 Talk › what torque setting for head bolts?
PostPosted: Sun Nov 06, 2011 5:22 pm Up
lost me haynes manual Confused need to know so i can torque up the head bolts on a 1.6 8v
Very Happy
PostPosted: Sun Nov 06, 2011 5:27 pm Up
Is it a cast iron or aluminum block. Got Haynes page in front of me
PostPosted: Sun Nov 06, 2011 5:28 pm Up
no idea, by the weight i would guess iron Laughing but unsure
PostPosted: Sun Nov 06, 2011 5:31 pm Up
Sent you a message on FB with torque settings attached
PostPosted: Sun Nov 06, 2011 5:43 pm Up
Don't forget that they are stretch bolts. They should be a maximum of 176.5 mm (underside of head to bolt tip). Any longer and you should replace all 10.
Some people would suggest you replace the bolts as a matter of course.
PostPosted: Sun Nov 06, 2011 5:52 pm Up
Yer there all new bolts, come with gasket as a deal. Thanks Smile
kingsway2468
PostPosted: Sun Nov 06, 2011 6:26 pm Up
You should have the torque settings and sequence with the head gasket
PostPosted: Sun Nov 06, 2011 6:38 pm Up
think all 8v block are cast iron
PostPosted: Mon Nov 07, 2011 3:24 am Up
No settings with gasket packaging kingsway.
And cheers seabrook Thumb Up , going by the weight I thought it might be Laughing could only just lift it off the floor
On my own.
